产品名称: PCI-531LF New
型  号: PCI-531LF New
品  牌: APLEX
ISA VIA Mark CPU Card w / VGA / Audio / LAN
Features:
Cost Effective Embedded Solution
Support VIA Mark CPU up to 533 MHz
Equipped with VIA Mark + VT82C686B chipsets
Supports DOC up to 288MB
Expansion Slot for PC104
Support Wake-on-LAN with ATX power
Specifications:
系统
CPU Support VIA MARK Processor
Chipset Mark + VT82C686B
DRAM 1 x 144-pin SO-DIMM, support PC100/133 SDRAM up to 512MB
BIOS Phoenix-Award PnP BIOS, with VGA BIOS
Watchdog 16 level Watchdog timer selectable w / Reset / NMI
Power Supply Support AT/ATX power
Power Requirement +5V, +12V
Power Consumption +5V : 2.74A / +12V : 0.065A (VIA Mark 533MHz)
+5V : 2.81A / +12V : 0.121A (VIA Mark 800MHz)
Dimension 185mm x 122mm ( 7.28" x 4.8" )
I/O 界面
IDE Interface 1 x 40-pin IDE ( UDMA 33/66/100 )
SSD 32-pin socket supports DOC up to 288MB
FDD Interface 1
Bus Interface PC/104
Serial Port 2 x COM ports, COM1 for RS232, COM2 for RS232/422/485 (for 16550 compatible type of UART)
Parallel Port 1 x parallel (SPP / EPP / ECP)
IrDA 1 ( SIR )
Keyboard Mini DIN connector or external connector
Mouse Mini DIN connector ( selectable w/KB ) or Y-cable
LAN
Realtek RTL8139D (10/100 Mbps)
Support Wake-on-LAN wtih ATX power
Audio AC 97 Codec, Realtek ALC202A With Line-in / Line-ou t/ MIC
USB 2 x USB 1.1
显示
Graphics Built-in VIA Mark, share system memory, Support CRT, TTL & LVDS
LCD Interface 18/24-bit TTL, 18/36-bit LVDS
环境
Operating Temp. 0 ~ 60 C ( 32 ~ 140 F)
Storage Temp. -40 ~ 85 C ( -40 ~ 185 F )
Humidity Operation humidity 20 ~ 90%, storage humidity 20 ~ 95%
Ordering Information:
型号 描述
ISA-382LF-C533   ISA CPU Card w VIA Mark 533MHz/ VGA / LAN (10/100Mbps)
关 键 词: 工业主板 APLEX
公司名称: 品富电子科技上海有限公司
联 系 人: 孔哲人
电  话: 021-54262303
手  机:
地  址: 上海市桂平路470号14号搂5层B区
邮  编: 200233
整机IP67全防水平板电(IP67)
APC-3081 人机(APC-3081)
品富AIX-503 MI(AIX-503)
品富AIX-510 MI(AIX-510)
APC-3716嵌入式平(APC-3716)
APC-3916嵌入式平(APC-3916)
APC-3516嵌入式平(APC-3516)
APC-3517嵌入式平(APC-3517)
APC-3717嵌入式平(APC-3717)
APC-3927嵌入式平(APC-3927)
APC-3262A嵌入式(APC-3262A)
APC-3562A嵌入式(APC-3562A)
AHM-6053 人机界(AHM-6053)
AHM-6127 NEW(AHM-6127 NEW)
AHM-6057 人机界(AHM-6057)
品富 AHM-6087 (AHM-6087)
品富 AHM-6107 (AHM-6107)
品富 AHM-6058 (AHM-6058)
品富 AHM-6108 (AHM-6108)
品富 AHM-6128 (AHM-6128)
