| ϵͳ |
| CPU Support |
Intel Core 2 Quad/ Core 2 Duo/ Celeron CPU with LGA775 CPU socket. (support Intel 65nm, 45nm Process Technology CPU) |
| CPU Frequency |
Core 2 Quad: 2.4~2.66GHz / Core 2 Duo: 1.8~3.0GHz / |
| Chipset |
Intel Q35 + ICH9DO (FSB: 800/1066/1333MHz) |
| DRAM |
2 ¡Á 240-Pin DDR2 DIMM, supports Dual channel memory architecture and DDR2 667/800MHz up to 4GB |
| BIOS |
Phoenix-Award PnP BIOS, with 32MB SPI flash |
| Watchdog |
1~255 secs Watchdog timer selectable w/Reset/NMI |
| Power Supply |
Support ATX power |
| Power Consumption |
+5V:3.3A, +12V:5.63A, +3.3V:1.64A, 5VSB:0.26A (USE INTEL CORE 2 QUAD Q6700 2.66GHz) |
| Power Requirement |
+5V, +12V, +3.3V, +5Vsb (from Backplane) |
| Dimension |
338.5 mm x 126 mm (13.33" x 4.96") |
| Certificate |
FCC / CE |
| I/O ½çÃæ |
| SATA Interface |
4 x S-ATA II connector (Raid 0,1,10,5) |
| TPM |
TPM1.2 1 with 20-pin header on board for TPM (Trusted Platfom Module) |
| Serial Port |
2 x COM port, COM 1 for RS232, COM 2 for RS232/422/485 ( for 16550 compatible type of UART) |
| Keyboard |
Mini DIN connector or external connector |
| Mouse |
| LAN |
LAN 1: Intel 82566DM (10/100/1000 Mbps) |
| Support |
Wake-on-LAN wtih ATX power |
| Audio |
High High Definition Audio |
| USB |
6 x USB 2.0 |
| ÏÔʾ |
| Graphics |
Built-in IntelR Q35, share system memory |
| LCD Interface |
18/24-bit LVDS |
| »·¾³ |
| Operating Temp. |
0¡ã~60¡ãC(32¡ã~140¡ãF) |
| Storage Temp. |
-40¡ã~85¡ãC(-40¡ã~185¡ãF) |
| Humidity |
Operation Humidity 20~90%, Storage Humidity 20~95% |
