| 产品名称: |
AHM-6121人机界面
| 型 号: |
AHM-6121 |
| 价 格: |
| 品 牌: |
产品介绍: |
| 12.1" RISC-based Human Machine Interface |
| 12.1”TFT LCD with resolution of 800x600 |
| 板载无风扇Intel Xscale PXA255处理器 |
| SMI SM501芯片支持双显示 |
| 1个CompactFlash Type I/II插槽 |
| 显示规格 |
| 显示 |
12.1"SVGA TFT LCD |
| 亮度 |
300 cd/m2 |
| 视角 |
120° (R/L) 95° (U/D) |
| 分辨率 |
800 x 600 |
| 背光 |
50,000 hrs |
| 系统与结构 |
| 架构 |
紧凑型塑料面框超薄设计 |
| 前面板颜色 |
黑色 |
| CPU |
Intel Xscale PXA255,400MHz |
| 存储 |
128MB DRAM 1MB SRAM with battery backup 32MB Flash for operating system CF slot for application software
128MB DRAM 1MB SRAM with battery backup 32MB Flash for operating system CF slot for application software |
| 电源 |
DC 11-28V |
触摸屏 |
4线式电阻式触摸屏 |
I/O 控制 |
COM1(RS-232/422/485),COM2(RS-232/) PS/2 port for keyboard or mouse USB Client 1.1 and Host 1.1 Ethernet port, External VGA port Speaker out x 1/Mic-in x 1 CF slot |
| 尺寸 |
317(W) x 50(D) x 243mm(H) |
| 重量 |
4.3kg/9.48 lbs |
| 环境规格 |
| 工作温度 |
0 - 50 ℃ |
| 储存温度 |
-20 - 60 ℃ |
| 储存湿度 |
10 ~ 95% @50 无冷凝 |
| 振动 |
5 - 17Hz, 0.1" double amplitude displacement 17 - 640Hz, 1.5G acceleration peak to peak |
| 冲击 |
10 to 25Hz (X,Y,Z direction 2G, 30 minutes) |
| 面板防护 |
NEMA 4/IP 65 compliant front panel |
| 认证 |
Meet CE / FCC Class A |
| 安装方式 |
上架式面板安装 / VESA 75支架安装 |
| OS 兼容性 |
Windows CE 4.2 / 5.0 | |
| 型号 |
描述 |
| AHM-6121 |
12.1" RISC-based Human Machine Interface w/resistive touch screen | | |
| 关 键 词: |
APLEX 人机界面 AHM-6121 |
