| 产品名称: |
AHM-6081人机界面
| 型 号: |
AHM-6081 |
| 价 格: |
| 品 牌: |
产品介绍: |
| 8” RISC-based Human machine Interface |
| 板载ARM 9 架构 Intel Xscale PXA255处理器 |
| Onboard with DRAM, Flash and SRAM memory bank |
| USB 1.1 host and 1.1 client supported |
| 紧凑型塑料面框超薄设计 |
| DC 11~28V wide-range power input |
| 显示规格 |
| 显示 |
8"SVGA TFT LCD |
| 亮度 |
400 cd/m2 |
| 视角 |
130° (R/L) |
| 分辨率 |
800 x 600 |
| 背光 |
40,000 hrs |
| 系统与结构 |
| 架构 |
紧凑型塑料面框超薄设计 |
| 前面板颜色 |
黑色 |
| CPU |
Intel Xscale PXA255,400MHz |
| 存储 |
128MB DRAM / 1MB SRAM with battery backup 32MB Flash for operating system CF slot for application software |
| 电源 |
DC 11-28V |
触摸屏 |
4线式电阻式触摸屏 |
I/O 控制 |
COM1 (RS-232/422/485), COM2 (RS-232) PS/2 port for keyboard or mouse, USB Client 1.1 and Host 1.1 1xEthernet port, 1xExternal VGA port, Speaker out x 1/Mic-in x 1 CF slot |
| 尺寸 |
231(W) x 57(D) x 176mm(H) |
| 重量 |
1.4kg/3.09 lbs |
| 环境规格 |
| 工作温度 |
0 - 50 ℃ |
| 储存温度 |
-20 - 70 ℃ |
| 储存湿度 |
10 ~ 95% @40 无冷凝 |
| 振动 |
5 - 17Hz, 0.1" double amplitude displacement 17 - 640Hz, 1.5G acceleration peak to peak |
| 冲击 |
10G acceleration peak to peak (11 millimeters) |
| 面板防护 |
NEMA 4/IP 65 compliant front panel |
| 认证 |
Meet CE / FCC Class A |
| 安装方式 |
上架式面板安装 / VESA 75支架安装 |
| OS 兼容性 |
Windows CE 4.2 / 5.0 | |
| 型号 |
描述 |
AHM-6081 Option |
8" RISC-based Human Machine Interface w/resistive touch screen WinXP Embedded including 512MB CF card | | |
| 关 键 词: |
APLEX 人机界面 AHM-6081 |
