产品介绍: |
| 17" Ultra Slim IP 65 Stainless Steel Fanless Panel PC |
| Water proof solution, totally IP 65 rating |
| Support Intel Celeron M 1GHz up to Pentium M 1.6GHz |
| 17" high brightness TFT LCD, 300cd/m2 |
| Sealed resistive touch screen |
| Support Mini-PCI, PCMCIA (optional), Compact Flash Type-II |
| DC 11~28V wide-range power input | |
| System Specifications |
| CPU |
| DRAM |
200/266-pin DDR SO DIMM up to 1GB |
| Storage |
Space for 1x2.5" HDD |
| Standard I/O ports |
DC power input, 1 x Ethernet port (10/100MB), 1 x PS/2 keyboard & mouse, 2 x USB 2.0 |
| Optional I/O ports |
2 x COM, 1 x VGA, 1 x Line-out |
| Touch Screen |
Analog Resistive (optional) |
| Expansion Slots |
MiniPCI slot x 1, optional PCMCIA |
| Fanless / Fan |
Fanless |
| Display Specifications |
| Display |
Stainless steel enclosure |
| Resolution |
1280x1024 |
| Luminance |
300 cd/m2 |
| Dimensions |
432(W)x358(H)x57(D)mm |
| Backlight |
50,000 hrs |
| Environment Specifications |
| Operating Temp. |
0 - 50 ℃ |
| Storage Temp. |
-20 -60 ℃ |
| Construction |
| Power Input |
DC 11~28V |
| Relative Humidity |
5-90% @40℃ non-condensing |
| Rating |
NEMA 4/IP 65 compliant front bezel |
| Certificate |
Meet CE / FCC Class A |
| Mounting |
VESA 75 mount |
| Order No |
Description |
2 x COM, 1 x VGA, 1 x Line-out | | |
