²úÆ·Ãû³Æ£º
APC-3596·ÀË®ÐÍÆ½°åµçÄÔ
ÐÍ ºÅ£º
APC-3596
| 15" Ultra Slim IP 65 Stainless Steel Fanless Panel PC |
| ¡¡ Water proof solution, totally IP 65 rating¡¡ |
| ¡¡ Support Intel Celeron M 1GHz up to Pentium M 1.6GHz ¡¡ |
| ¡¡ 15" high brightness TFT LCD, 400cd/m2¡¡ |
| ¡¡ Sealed resistive touch screen¡¡ |
| ¡¡ Support Mini-PCI, PCMCIA (optional), Compact Flash Type-II¡¡ |
| ¡¡ Space for 1 x 2.5" HDD¡¡ |
| ¡¡ Support VESA 75 mount¡¡ |
| ¡¡ DC 11~28V wide-range power input¡¡ | |
| System Specifications |
| CPU |
Intel Celeron M 1GHz up to Pentium M 1.6GHz¡¡ |
| DRAM |
200/266-pin DDR SO DIMM up to 1GB ¡¡¡¡ |
| Storage |
Space for 1x2.5" HDD ¡¡¡¡ |
| Standard I/O ports |
DC power input, 1 x Ethernet port (10/100MB), 1 x PS/2 keyboard & mouse, 2 x USB 2.0¡¡ |
| Optional I/O ports |
2 x COM, 1 x VGA, 1 x Line-out ¡¡¡¡ |
| Touch Screen |
Analog Resistive (optional)¡¡ |
| Expansion Slots |
| Fanless / Fan |
Fanless¡¡¡¡ |
| Display Specifications |
| Display |
15" XGA ¡¡ |
| Resolution |
1024x768 ¡¡¡¡ |
| Luminance |
400 cd/m2 ¡¡¡¡ |
| Dimensions |
399(W)x324(H)x63(D)mm ¡¡ |
| Backlight |
50,000 hrs ¡¡¡¡ |
| Environment Specifications |
| Operating Temp. |
0 - 50 ¡æ¡¡ |
| Storage Temp. |
-20 -60 ¡æ¡¡ |
| Construction |
Stainless steel enclosure ¡¡ |
| Power Input |
DC 11~28V¡¡ |
| Relative Humidity |
5-90% @40¡æ non-condensing¡¡ |
| Rating |
NEMA 4/IP 65 compliant front bezel ¡¡¡¡ |
| Certificate |
Meet CE / FCC Class A¡¡¡¡ |
| Mounting |
VESA 75 mount ¡¡¡¡ |
| Order No |
Description |
| ¡¡ Optional I/O ports¡¡ |
2 x COM, 1 x VGA, 1 x Line-out ¡¡ | | |
