产品介绍: |
| 17" SXGA Open Frame Display Monitor |
| 1280(H)x1024(V), 300 cd/m2 |
| Resistive touch screen (optional) |
| Optional DVI, Video or S-Video input |
| Auto Recognition of Input Signal |
| AC 100~240V wide-range power input | |
| 显示规格 |
| 显示 |
17" Color Active TFT Flat Panel Display |
| 亮度 |
300 cd/m2 |
| 视角 |
140/130 °(H/V) |
| 分辨率 |
1280 x 1024 (native mode), 262K colors |
| 背光 |
50,000 hrs |
| 触摸屏 |
Antiglare Resistive (optional) |
| OSD 控制 |
Automatic Screen, Setup (OSD), Brightness, Contrast, Horizontal / Vertical Position, Image Lock, Color Balance, Video Information, Power On and Sync detected |
| 电源 |
AC 100~240V |
| 结构规格 |
| 架构 |
Steel chassis & front panel |
| 尺寸 |
457(W)x355(H)x70(D)mm |
| 重量 |
6.77kgs |
| 环境规格 |
| 工作温度 |
0 - 50 ℃ (32 - 122℉) |
| 储存温度 |
-20 - 60 ℃ (-4 - 140 ℉) |
| 储存湿度 |
10 - 90% @40℃ Non-condensing, without touch screen |
| 振动 |
1G peak, 5 ~ 500Hz (Random) |
| 冲击 |
15G peak acceleration (11 msec, duration) |
| 认证 |
Meet CE / FCC Class A |
| Order No |
Description |
OPD-1170 Option |
17" SXGA open frame display monitor resistive touch screen | | |
