| Display Specifications |
| Display |
17" Color Active TFT Flat Panel Display |
| Luminance |
300 cd/m2 |
| Viewing Angle |
140/130 °(H/V) |
| Resolution |
1280 x 1024 (native mode), 16.2M colors |
| Backlight |
50,000 hrs |
| Touch Screen |
Analog resistive (optional) |
| OSD Controls/Indicators |
On the front side |
| Power Input |
AC 100~240V, optional DC 11~28V |
| I/O Connectors |
1xAC power input, 1xVGA, optional: DVI, S-Video, RCA, touch (RS-232 or USB) |
| Mechanical Specifications |
| Construction |
Steel front bezel & steel chassis |
| Dimensions |
439(W)x348(H)x64.7(D)mm |
| Mounting |
Panel / VESA 75 mount |
| Weight |
| Environment Specifications |
| Operating Temp. |
0 - 45 ℃ (32 - 113 ℉) |
| Storage Temp. |
-20 ~-60 ℃ (-4 - 140 ℉) |
| Relative Humidity |
10 - 90% @40℃ Non-condensing, without touch screen |
| Vibration |
1G peak, 5 - 500Hz (Random) |
| Shock |
15G peak acceleration (11 msec, duration) |
| Rating |
NEMA 4/IP 65 compliant front bezel |
| Certificate |
Meet CE / FCC Class A |
