产品介绍: |
| 15" Color TFT Industrial Display Monitor |
| Front Panel NEMA 4/IP 65 rating |
| Resistive touch screen (optional) |
| OSD control on the front side |
| Optional DVI, Video and S-Video input |
| Optional Aluminum front bezel |
| Support Panel / VESA 75 mount |
| Support wide-ranging resolutions from 640 x 480 to up to 1600 x 1200 with auto phase and auto position |
| AC 100~240V, optional DC 11~28V power input | |
| 显示规格 |
| 显示 |
15" Color Active TFT Flat Panel Display |
| 亮度 |
400 cd/m2 |
| 视角 |
140/125 °(H/V) |
| 分辨率 |
1024 x 768 (native mode), 16.2M colors |
| 背光 |
50,000 hrs |
| 触摸屏 |
Analog resistive (optional) |
| OSD 控制 |
On the front side |
| I/O 控制 |
1xAC power input, 1xVGA, optional: DVI, S-Video, RCA, touch (RS-232 or USB) |
| 电源 |
AC 100~240V, optional DC 11~28V |
| 结构规格 |
| 架构 |
Steel front bezel & s teel chassis |
| 尺寸 |
409(W) x 309(H) x 64.7(D) mm |
| 安装 |
| 重量 |
5.32kgs |
| 环境规格 |
| 工作温度 |
0 - 50 ℃ (32 - 122℉) |
| 储存温度 |
-20 - 60 ℃ (-4 - 140 ℉) |
| 储存湿度 |
10 - 90% @40℃ Non-condensing, without touch screen |
| 振动 |
1G peak, 5 - 500Hz (Random) |
| 冲击 |
15G peak acceleration (11 msec, duration) |
| 面板防护 |
NEMA 4/IP 65 compliant front bezel |
| 认证 |
Meet CE / FCC Class A |
| Order No |
Description |
| Optional |
Aluminum front bezel & steel chassis | | |
