| 显示规格 |
| 显示 |
15" Color Active TFT Flat Panel Display |
| 亮度 |
400 cd/m2 |
| 视角 |
140/125 °(H/V) |
分辨率 |
1024 x 768 (native mode), 16.2M colors |
| 背光 |
50,000 hrs |
| 触摸屏 |
Analog resistive (optional) |
| OSD 控制 |
On the back side |
| I/O 控制 |
1xAC power input, 1xVGA, optional: DVI, S-Video, RCA, touch (RS-232 or USB) |
| 电源 |
AC 100~240V, optional DC 11~28V |
| 系统与结构 |
| 架构 |
Steel chassis & front panel |
| 尺寸 |
410 (W)x310(H)x69(D)mm |
| 安装 |
Panel Mount / Rack Mount (optional) |
| 重量 |
5.35kgs |
| 环境规格 |
| 工作温度 |
0 - 50 ℃ (32 - 122 ℉) |
| 储存温度 |
-20 - 60 ℃ (-4 ~ 140 ℉) |
| 储存湿度 |
10 - 90% @40℃ Non-condensing, without touch screen |
| 振动 |
1G peak, 5 - 500Hz (Random) |
| 冲击 |
15G peak acceleration (11 msec, duration) |
| 面板防护 |
NEMA 4/IP 65 compliant front bezel |
| 认证 |
Meet CE / FCC Class A |
