| 显示规格 |
| 显示 |
12.1" Color Active TFT Flat Panel Display |
| 亮度 |
300 cd/m2 |
| 视角 |
120 / 95 °(H/V) |
| 分辨率 |
800 x 600 (native mode), 262K colors |
| 背光 |
50,000hrs |
| 触摸屏 |
Analog resistive (optional) |
| OSD 控制 |
On the back side |
| 电源 |
DC 12V, optional DC 11~28V |
| I/O 控制 |
1xDC power input, 1xVGA, optional: DVI, S-Video, RCA, touch (RS-232 or USB) |
| 结构规格 |
| 架构 |
Heavy-duty steel chassis with plastic front bezel |
| 尺寸 |
317(W)x243(H)x45(D)mm |
| 安装 |
Panel Mount / VESA Mount |
| 环境规格 |
| 工作温度 |
0 - 50 ℃ (32 - 122 ℉) |
| 储存温度 |
-20 - 60 ℃ (-4 ~ 140 ℉) |
| 储存湿度 |
10 - 95% @40℃ Non-condensing |
| 振动 |
1G peak, 10~150Hz (Random) |
| 冲击 |
30G peak acceleration (11 msec, duration) |
| 面板防护 |
NEMA 4/IP 65 compliant front bezel |
| 认证 |
Meet CE / FCC Class A |
