tes1300 接触式测温仪
tes1300 接触式测温仪产品简介:
·最大值锁定
·读值锁定
·Aux output JACKS
·T1 - T2 differential measurement
tes1300 接触式测温仪技术指标:
测量范围 |
-50℃ -1300℃; -50℉ -1999℉ |
感应器 |
K Type thermocouple |
输入 |
Single(1300), Dual (1302,1303) |
分辨率 |
-50℃ + 199.9℃...0.1℃ |
-50℉ + 199.9℉...0.1℉ (Others-1℃/1℉) |
准确度 |
-50℃to 199.9℃...0.3% rdg + 1℃ |
-50℉to 199.9℉...0.3% rdg + 2℉ |
-50℃to 1000℃... 0.5% rdg + 1℃ |
-50℉to 1999℉. ..0.5% rdg + 2℉ |
1000℃ to 1300℃..0.75% rdg + 1℃ |
(apply to mainframe only at 23℃±5℃) |
功能 |
H Data Hold & Display ℃/℉ 选择 |
0.1°/1° 分辨率选择 |
T1 & T2 dual points display |
T1 - T2 differential measurement |
3-1/2 digit LCD |
Overange: 1------ |
低电池指示: BT |
Temperature Coefficient |
Less than 0.1 time the applicable |
accuracy specification per ℃ (℉) |
输入保护 |
热电隅最大输入电压:60V DC or 24 Vrms AC |
取样率:每秒 2.5次 |
