»ØÂ·Ð£ÑéÒǼò½éYHS-717/S
YHS717/S»ØÂ·Ð£×¼ÒÇÊǶԵçÁ÷»ØÂ·½øÐÐУ׼¡¢Î¬ÐÞºÍά»¤µÄ¡£¸ßÐÔÄܽâ¾ö·½°¸¡£ÐÂÐ͵ĿìËÙ¸ÐÓ¦ÐýťʹÆä·Ç³£¿ìËÙ¡¢Ò×Óᢳ¤ÊÙÃü¡£ËüºÍYHS707Ïà±ÈÖ÷ÒªÊÇµç³Ø²ÉÓÃÁËÂÌÉ«»·±£Ð͵Ŀɳäµç´óÈÝÁ¿ï®µç³Ø£¡´ýµçʱ¼ä³¤£¬¿É½ÚÔ¼´óÁ¿ÔËÓª·ÑÓã¡
Ö÷ÒªÌØµãÓУº
¡¤Ê¹ÓÿìËÙ¸ÐÓ¦ÐýÅ¥£¬µ¥ÊÖ¼´¿É²Ù×÷
¡¤mAµçÔ´¡¢·ÂÕæºÍ²âÁ¿¹¦ÄÜ
¡¤0.02% µÄ׼ȷ¶ÈºÍ0.001mAµÄ·Ö±æÂÊ
¡¤Í¬Ê±ÏÔʾmAºÍÁ¿³ÌµÄ°Ù·Ö±È
¡¤¿ÉÑ¡µÄ²½½øºÍб²¨Êä³ö
¡¤24V»ØÂ·µçÔ´£¬½øÐÐmA²âÁ¿£¬°üÀ¨250¦¸µÄHARTµç×èÆ÷
¡¤0-28Ö±Á÷µçѹ²âÁ¿¡¤²»¿ª¸Ç¼´¿É·½±ãµØ¸ü»»µç³Ø
¡¤½ô´ÕµÄÉè¼Æ½á¹¹£¬¾ßÓпɲðжµÄ·À»¤Ìס£
¼¼Êõ¹æ¸ñ
µçÁ÷²âÁ¿
Á¿³Ì£º 0ÖÁ24mA
·Ö±æÂÊ£º 0.001mA
׼ȷ¶È£º 0.02%¶ÁÊý+4¸ö×îµÍÓÐЧλ
Êä³öµçÁ÷
·¶Î§£º 0ÖÁ20mA»ò4ÖÁ 20 mA
Çý¶¯ÄÜÁ¦£º1200¦¸£»950¦¸@20mA£¬HARTģʽ
µçÁ÷·ÂÕæ
·¶Î§£º0ÖÁ20mA »ò4ÖÁ20mA
Íⲿ»ØÂ·µçѹҪÇó£º12-30V
»ØÂ·µçÔ´ 24V
µçѹ²âÁ¿
·¶Î§£º0ÖÁ28V DC
·Ö±æÂÊ£º1mV
YHS-717 Loop Calibrator
features
The fast, one-handed tool for loop checks. Just click to calibrate.
This feature-rich solution combines the best features push-button and knob-base loop calibrator and offers:
- Large display and simple, quick-click interface for easy one-handed operation.
- Simultaneous mA and % readout for quick, easy interpretation of readings.
- mA accuracy of 0.02%, superior to other loop calibrators in this price range.
- 1 µA resolution for mA source, simulate and measure.
- Push button 25% steps for fast, easy linearity checks.
- 0-100% ¡°span check¡± for fast confirmation of zero and span.
- Selectable slow ramp, fast ramp, and step ramp to provide smooth outputs for valve slewing and loop functional tests.
- 24 volt internal loop supply, so you can power and read a transmitter at the same time without carrying a DMM.
- Measures V dc to 28 V.
- Single 9V battery that is easily changed without braking calibration seal
- 0 - 20 mA or 4 - 20 mA default start up modes.
- Innovative output adjustment dial with 1 µA and 100 resolution.
- HART 8482; mode connects 250 ¦¸ resistor in series with 24 V loop for compatibility with HART communicators.
Specifications
Current Measurement |
Range: |
0 to 24 mA |
Resolution: |
0.001 mA |
Accuracy: |
0.02% Rdg + 4 LSD |
Current Sourcing |
Range: |
0 to 20 mA or 4 to 20 mA |
Accuracy: |
0.02% Rdg + 4 LSD |
Drive Capability: |
1200 ¦¸; 950 ¦¸ at 20 mA in HART mode |
Current Simulation |
Range: |
Accuracy: |
0.02% Rdg + 4 LSD |
Ext. loop voltage requirement: |
12-30 V |
Loop Power |
While measuring mA, 24 V |
Voltage measurement |
Range: |
0 to 28 V DC |
Resolution: |
1 mV |
Accuracy: |
0.02% Rdg + 4 LSD |
Environmental Specifications
Operating Temperature -10ºC to 55ºC
Storage Temperature -30ºC to 60ºC
Humidity (Without Condensation) 0 to 90% (0ºC to 35ºC); 0 to 70% (35ºC to 55ºC)
Temperature Coefficient -10ºC to 18ºC, 28ºC to 55ºC, ¡À.005% of range per ºC
Safety Specifications
Maximum voltage 30V
Mechanical & General Specifications
Size 152 x 70 x 41 mm
Weight 224 g (340 g including holster)
Batteries a group of large capcity Lithium Battery (7.4V)
Warranty Two years
Shock & Vibration per MIL-T-28800 for a Class 2 Instrument
Display current and % of span Yes
Auto step, auto ramp Yes
Span Check Yes
