²úÆ·Ãû³Æ£º PCI-8124
ÐÍ ºÅ£º PCI-8124
Æ· ÅÆ£º ADLINK
Features
  • Four channel encoders with OUT/DIR, CW/CCW and A/B phase
  • Internal FIFO: Save 512 points per channel
  • 32-bit encoder & comparator
  • Pulse width is adjustable from 0.5 us to 1.6ms
  • Dual I/O design - Isolation & TTL
  • Support linear and random trigger function for position compare
  • Mapping of comparator and trigger is configurable
  • Homing by the rising edge of EZ signal
Introduction
PCI-8124 is a 4 channel trigger board which is suitable for advanced line scan application which need high line rates. PCI-8124 has internal FIFO to realize the high speed position compare and trigger pulse output. The frequency can be up to 30KHz. For this application, ADLINK proposes you can use PCI-8134 and PCI-8124 together to gain the advantage of motion control and high speed trigger function. For position compare, PCI-8124 provides two method: linear function or variable interval. PCI-8124 also provide the variety of mapping function between comparator and trigger output. The comparator condition can be associated with latch signal, TTL input and EA/EB signal.
¹«Ë¾Ãû³Æ£º Á軪¿Æ¼¼£¨Öйú£©ÓÐÏÞ¹«Ë¾
µç »°£º 010 58858666ת8830 / ÕŸ£Ç¿
ÊÖ»ú£º
µØ Ö·£º ±±¾©º£µíÇøÉϵض«Â·1ºÅÓ¯´´¶¯Á¦´óÏÃE×ù°Ë²ãÎ÷
ÓÊ ±à£º 100085
Ö÷ Ò³£º http://www.adlinktech.com
  • PXIS-2719
  • PXIS-2558T
  • PXI-3910
  • PXI-3920
  • PXI-3950
  • PCIe-RTV24
  • PCI-8144
  • PCI-8102
  • PCI-8124
  • PCI-8134
