¹©Ó¦µÂ¹úGEMCO´«¸ÐÆ÷ GEMCOÄ£¿é GEMCO¿ª¹Ø GEMCOÖÆ¶¯Æ÷
ÉϺ£²Æ²ýʵҵ·¢Õ¹ÓÐÏÞ¹«Ë¾´úÀí¾ÏúµÂ¹úGEMCO´«¸ÐÆ÷ GEMCOÄ£¿é GEMCO¿ª¹Ø GEMCOÖÆ¶¯Æ÷ϵÁвúÆ·£¬ÈçÄú¶Ô¸Ã²úÆ·ÓÐÐËȤ£¬»¶ÓËæÊ±À´µç×Éѯ£¡
µÂ¹ú¸ÇÄ·¿ÆGEMCO ´«¸ÐÆ÷/SENSOR/Î»ÒÆ´«¸ÐÆ÷/ÏßÐÔ´«¸ÐÆ÷/͹ÂÖ¿ª¹Ø/Ä£¿é/ÏÞλ¿ª¹Ø/ɲ³µ/ÖÆ¶¯Æ÷/
µÂ¹ú¸ÇÄ·¿ÆGEMCO¹«Ë¾Éú²úµÄ´ÅÖÂÉìËõÏßÐÔÎ»ÒÆ´«¸ÐÆ÷ÊÊÓÃÓÚ¶àÖÖ²»Í¬µÄ¹¤Òµ×Ô¶¯»¯ÐÐÒµ£¬ÌرðΪ¸ÖÌúÒ±½ðÐÐÒµÁ¿Éí¶¨ÖÆ¡£ÈçÔÚÒ±½ðÐÐÒµÖУ¬Ö÷ÒªÓÃÓÚÒ±Á¶¡¢Ôþ¸ÖϵͳµØËÅ·þҺѹ¸×Á¬ÐøÎ»ÖòâÁ¿ºÍ·´À¡£¬´ÓÒ±Á¶¡¢Á¬Öý¡¢ÈÈÔþ¡¢Öа塢ºñ°å¡¢ÀäÔþ¡¢´¦ÀíÏß¡¢°ôÏ߲ġ¢HÐ͸ÖÉú²úÏߵȣ¬×îÓдú±íÐÔµÄÓ¦ÓÃÊÇÈÈÁ¬Ôþ³§ÖÐÀûÓÃGEMCO´ÅÖÂÉìËõÏßÐÔÎ»ÒÆ´«¸ÐÆ÷×÷ҺѹAGC¿ØÖƺÍAPC¿ØÖÆ£¬GEMCO´ÅÖÂÉìËõÏßÐÔÎ»ÒÆ´«¸ÐÆ÷°Ñ·Ö±æÂʺÍÖØ¸´¾«¶ÈÌáÉýÖÁ1.5¦Ìm¡£²¢¾ßÓÐÒÔÏÂ׿ԽÐÔÄÜ£º
1£º¹¤×÷ζȣº--40~85¡æ
2£º¿¹³å»÷£º1000G£¬ ¿¹Õ𶯣º30G£¨ÓÅÓÚMTS£©
3£º·À»¤µÈ¼¶£ºIP68£¨ÓÅÓÚMTS£©
4£º¿ÉÒÔÖ±½ÓÓëMTSºÍBALLUFÁ¬½Ó²åÍ·Æ¥Åä
5£ºCEÈÏÖ¤
6£º25ÄêÎÞ¹ÊÕÏÔËÐУ¬Ãâά»¤
GEMCO´ÅÖÂÉìËõÏßÐÔÎ»ÒÆ´«¸ÐÆ÷ÔÚÒÔÏÂÐÐÒµÖл¹¾ßÓдóÁ¿µÄÓ¦Óð¸Àý¡£
1£º ÔìÖ½ÐÐÓ¡Ë¢ÒµÖУ¬³£ÓÃÓÚ´øÉÏϹöͲµÄ¾íÖ½»ú£¬°²×°ÓÚÉϹöͲÓ͸ף¬¿ØÖÆÉÏϹöͲ¼äµÄ¼ä϶¾àÀëÒÔ¼°±ãÓÚ¿ìËÙ¸ü»»¾íÂúµÄ¹öͲ
2£ºÔÚÆøÑ¹¸×·½Ãæ¡£ ±»ÓÃ×÷ËÅ·þÆøÑ¹¸×µÄ·´À¡×°ÖÃ
3£ºÔÚË®Àû¹¤³ÌºÍ¸Û¿Ú»úеÉÏ£¬GEMCO´ÅÖÂÉìËõÏßÐÔÎ»ÒÆ´«¸ÐÆ÷°²×°ÓÚ³¤Ðг̵ÄҺѹ¸×ÉÏÒÔ¿ØÖÆË®°ÓÕ¢ÃŵĿª¹Ø£¬
4£ºÄ¾²Ä¼Ó¹¤£¬×¢ËÜ»ú£¬¶Íѹ»ú´²£¬Ï𽺻úе
950MD019500XR£¬950MD24AOBOCXF£¬951-AV-0520-N-2-D5-E£¬951AV0520N2D5E£¬951V0710XXE£¬951AV0030N2XE£¬951AV0195N2D5C12£¬952AV10330XX5£¬
952QD0600XXE1270CF6M1NDX£¬01533002LXX£¬
AM-04537080£¬14570001£¬01533002L100£¬01533002L2000£¬01533002L300£¬1025-A-1DP-S£¬1025-A-1DP-X£¬1025-B-1A4-S-X£¬1025-B-1DP-P-X£¬
1025-B-2DP-S-X£¬1025-B-2SP-G-X£¬1025-C-2DP-S£¬1025-C-2SP-S£¬1771-PLS-B1£¬1950-1-B-A-AO£¬1950-1-B-A-AR£¬1950-1-B-A-DO£¬
950-1-D-A-AO£¬1950-1-P-A-AR£¬1950-4-B-A-AO£¬1950-4-P-A-AO£¬1950G-1-B-A-AR£¬1980-101-R-SP-X£¬1980-103-L-SP-X£¬1980-103-R-SP-TD1£¬
1980-104-D-DPP-R-X-S-200-R£¬1980-107-R-DP-X £¬1980-105-X-SP-X-R-1-L7£¬1980-105-R-SP-TD1£¬£¬1980-106-D-SP-X£¬
1980-106-X-SP-R-X-S-32-L£¬1980-108-D-SD-TW1£¬1980-111-R-SP-TD2£¬1980-112-X-SP-R-X-S-6-R£¬1980-112-X-SP-X-R-5-L1£¬
1980-118-X-SP-TD1-S-1.5-L£¬1980-1203-R-SP-R-X£¬1980-1204-D-DP-X£¬1980-1204-D-SPG-R-X£¬1980-1204-X-SP-R-72-L1£¬
1980-1206-X-DP-X-S-1.33-L£¬1980-403-R-SP-TD1£¬1980-406-Y-SP-TD1-S-15-L£¬1986-1781A£¬1986A-1-D1-R-X£¬1986A-1-GR03-R-E£¬
1986A-1-GR18-B60-PSA£¬1986A-1-X-R-E£¬1986A-DN-GR6-1-R-X£¬1989-A-32-R-12-S-E-M£¬1989-CA-16-R12-S-E-H-RMO£¬1999OPT5YRWRNTY£¬
2000-1122B£¬2006-402-L-30-B£¬2006-402-L-357-A£¬2110-L1-K0-D0-A0-N0£¬2500-WINN-CD£¬2500C-B-A-R-A-0A8D-X-12£¬439C394G01£¬
71211SN1MM00N0C111C8£¬909-66-AA-10-R£¬925-A2-144-72-S-X£¬925-B1-168-72-S-X£¬949-021L12£¬950MD-11A-0B-0C-X-X£¬950MD-18A-0B-0C-X-R£¬
950MD-24A-0.5B-0.5C-C2-X£¬950MD-30A-0B-0C-X-B1£¬950MD-32A-2B-2C-X-X£¬950MD-45A-0B-0C-X-X£¬950MD-46A-0B-0C-X-B1£¬
950MD-665A-0B-0C-C2-X£¬950MD-84A-0B-0C-X-R£¬951A-C1-0040-X-X-E£¬951A-C1-0050-N2-D2-E£¬951A-C1-0060-N3-D5-E£¬
951A-C1-0088-N2-D5-C12£¬951A-C1-0183-N2-D5-E£¬951A-C1-0330-N3-D6-E£¬951A-C1-0460-X-X-E£¬951A-V-0010-X-X-E£¬
951A-V-0110-N2-D5-C12£¬951A-V-0250-X-X-C15£¬951A-V-0320-N3.5-X-C12£¬951A-V-0900-X-X-C10£¬951CP-0268-N2-D5-E£¬
951CP-1996-12£¬951VP-0120-X-X-I-E£¬951VP-1992-33£¬952A-C4-0015-X-X-T£¬952A-C4-0180-X-D5-C6£¬952A-C4-0200-X-D5-S£¬
952A-C4-0360-X-X-S£¬952A-V0-0200-X-D5-E£¬952A-V1-0330-X-X-S£¬952CP-0080-X-X-E£¬952QD-0100-X-X-C6-1000-EF4£¬952RS-0030-X-X-C6£¬
952RS-0180-X-X-C6£¬952VP-0300-X-X-E-E-002£¬952VP-0960-N2.5-D5-E-I-001£¬952VP-2110-16£¬952VP-21104£¬953A-C4-0070-X-X-S-X£¬
953A-C4-0118-X-X-S-X£¬953A-C4-0300-X-D2.5-S-X£¬953A-C4-0600-X-D2.5-S-X£¬953A-V0-0060-X-X-M-X£¬953A-VO-0900-X-C10-X£¬
955A-C4-0120-X£¬955A-C4-0200-X£¬955A-V0-0958-E£¬955ARM6£¬955D-RS-1060-X£¬955LC-C4-0360£¬955S-C4-0070£¬955S-C4-0510£¬
956A-C4-0090-E£¬956A-C4-0130-X£¬956S-VO-0110-E£¬A/H-ARC 2-18£¬A/HM-ERC£¬BZ-2RW22-A2£¬ET-10DC£¬ET-11NA£¬ET-13DC£¬ET-14NA DC£¬
TMSC-1035£¬PLSIO-D-16-XX-8-X£¬SD0284200-R50-R1£¬SD02842C-R12-R6£¬SD0334900L15£¬SD0334900LXX£¬SD0372700-R-2-R1£¬SD0399000L25£¬
SD0410600L314£¬SD0508200L60£¬SD0528500L2.5£¬SD2842C£¬TMSCH-1355£¬UB-PS-8407-281EP
