²úÆ·Ãû³Æ£º PXI-3910
ÐÍ ºÅ£º PXI-3910
Æ· ÅÆ£º ADLINK
Features
  • PXI™ specification Rev. 2.2 Compliant
  • Equipped with Intel® Celeron® M 373 1.0 GHz processor
  • On-board soldered CPU and memory to provide excellent resistance to shock and vibration
  • On-board 512 MB 400 MHz DDR2 memory
  • Integrated 80 GB SATA hard drive
  • Dual Gigabit Ethernet ports
  • Four USB 2.0 Ports
  • Built-in GPIB (IEEE488) controller
Introduction
ADLINK PXI-3910 is a next-generation PXI™ embedded controller designed for hybrid PXI-based testing systems. It provides plenty of interfaces, including GPIB, USB and COM ports, for connecting and controlling instruments. In addition, the PXI-3910 is the first PXI controller come with dual-Gigabit Ethernet ports for controlling next-generation LXI instruments. The PXI-3910 is cautiously designed to provide maximal robustness. It has cable-free mechanical construction and is extremely durable. The CPU and memory chips are soldered on the PCB to increase reliability in shock and vibration prone environments. The alumni-copper composite heat sink helps to disperse heat uniformly to maintain a stable operating temperature. Combining a variety of instrument control interfaces and reliable mechanical and electronic design, ADLINK PXI-3910 is well endowed to meet the needs of your hybrid PXI-based testing systems.
Ordering Information
PXI-3910 3U PXI Celeron M 373 1.0 GHz System Controller with DVI-I/Dual GbE/GPIB, built-in 512 MB DDR2 memory and 80 GB SATA HDD
ACL-IEEE488-MD1 25-pin micro-D to GPIB cable, 1 meter length
Associated Software
PXI_Platform_ Description v2.0 PXI Platform Description Files v2.0
¹«Ë¾Ãû³Æ£º Á軪¿Æ¼¼£¨Öйú£©ÓÐÏÞ¹«Ë¾
µç »°£º 010 58858666ת8830 / ÕŸ£Ç¿
ÊÖ»ú£º
µØ Ö·£º ±±¾©º£µíÇøÉϵض«Â·1ºÅÓ¯´´¶¯Á¦´óÏÃE×ù°Ë²ãÎ÷
ÓÊ ±à£º 100085
Ö÷ Ò³£º http://www.adlinktech.com
  • PXIS-2719
  • PXIS-2558T
  • PXI-3910
  • PXI-3920
  • PXI-3950
  • PCIe-RTV24
  • PCI-8144
  • PCI-8102
  • PCI-8124
  • PCI-8134
