一.大A系列
一,CPU:
A3ACPU A3ACPUP21 A3ACPUR21 A2ACPU-S1 A2ACPUP21-S1
A2ACPUR21-S1 A2ACPU A2ACPUP21 A2ACPUR21 A3NCPU
A3NCPUP21 A3NCPUR21 A2NCPU-S1 A2NCPUP21-S1 A2NCPUR21-S1
A2NCPU A2NCPUP21 A2NCPUR21 A1NCPU A1NCPUP21
A1NCPUR21 A0J2CPU A0J2HCPU A0J2HCPUP21 Q2ACPU
Q2ACPU-S1 Q3ACPU Q4ACPU Q4ARCPU A221AM-20
二.底板
A32B A35B A38B A55B A58B A65B A68B A38HB
三.电源 A61P A62P A63P A65P A66P A68P
四.内存卡
A3NMCA-0 A3NMCA-2 A3NMCA-4 A3NMCA-8 A3NMCA-16
A3NMCA-16 A3NMCA-24 A3NMCA-40 A3NMCA-56 A4UMCA-128
4KRAM 16KRAM 4KROM 8KROM 16KROM 16KHROM
16KQROM 4KEROM 64KWROM 128KWROM 256KWROM
五:A6BSW-P-S3 A6BSW-P-S4 A6BSW-P-S5
六. 输入模块
AX10 AX11 AX20 AX21 AX40 AX41 AX41-S1
AX42 AX42-S1 AX60-S1 AX70 AX71 AX80E
AX81 AX82
七. 输出模块
AY10 AY10A AY11 AY11A AY13 AY13E AY22
AY23 AY40 AY40P AY41 AY42 AY42-S1
AY42-S3 AY50 AY51 AY51-S1 AY51UL
AY60 AY60S AY70 AY71 AY80 AY81EP AH42
八. 特殊模块
A68AD A68ADN A616AD A60MX A60MXR
A616TD A68DAV A68DAI-S1 A616DAV A616DAI
A68RD3 AD61 AD61-S1 AD71-S2 AD71TU
AD72 AD75P1-S3 AD75P2-S3 AD75P3-S3
AD75M1 AD75M2 AD75M3 AD51H-S3 AJ71C24-S8
AJ71C24-S3 AJ71UC24
九. 网络模块
AJ71E71N-B5T AJ71E71N-B2 A7BDE-J71AP21
AJ71AP21 AJ71AR21 AJ72P25 AJ72R25
AJ71AT21B AJ72T25B AJ71PT32-S3 AJ71LP21
AJ71LP21G AJ71BR11 AJ61BT11 AI61
A11VC AG62 A7PU AJ71QC24 AJ71QC24-R2
AJ71QC24N-R2 AJ71QLP21 AJ71QLP21G AJ71QBR11
AJ61QBT11 A7BDE-J71AR21 AJ71LP21GE
A6BR10 A6BR10-DC A8PUE AC20R4-A8PU AC300R4
AC30R4 AC30R2 A6SW16 A6SW32
十:远程通信模块:
AJ65SBTB1-8D AJ65SBTB1-16D AJ65SBTB1-16D1 AJ65SBTB1-32D
AJ65SBTB1-32D1 AJ65SBTB2N-8A AJ65SBTB2N-16A AJ65SBTB3-8D
AJ65SBTB3-16D AJ65SBTC1-32D AJ65SBTC1-32D1 AJ65SBTC4-16D
AJ65SBTCF1-32D AJ65FBTA4-16D AJ65FBTA4-16DE AJ65SBTW4-16D
AJ65MBTL1N-16D AJ65MBTL1N-32D AJ65BTB1-16D AJ65BTB2-16D
AJ65BTC1-32D AJ65SBTB1-8T AJ65SBTB1-8T1
AJ65SBTB1-16T1 AJ65SBTB1-32T AJ65SBTB1-16T1 AJ65SBTB1-32T1
AJ65SBTB2-8T AJ65SBTB2-8T1 AJ65SBTB2-16T AJ65SBTB2-16T1
AJ65SBTB2N-8R AJ65SBTB2N-16R AJ65SBTB2N-8S AJ65SBTB2N-16S
AJ65SBTC1-32T AJ65SBTC1-32T1 AJ65SBTCF1-32T AJ65FBTA2-16T
AJ65FBTA2-16TE AJ65MBTL1N-16T AJ65MBTL1N-32T AJ65BTB1-16T
AJ65BTB2-16R AJ65BTB2-16T AJ65BTC1-32T AJ65SBTB1-16DT
AJ65SBTB1-16DT1 AJ65SBTB1-16DT2 AJ65SBTB1-16DT3
AJ65SBTB1-32DT AJ65SBTB1-32DT1 AJ65SBTB1-32DT2
AJ65SBTB1-32DT3 AJ65SBTB32-8DT AJ65SBTB32-8DT2
AJ65SBTB32-16DT AJ65SBTB32-16DT2 AJ65SBTC1-32DT
AJ65SBTC1-32DT2 AJ65SBTC1-32DT3 AJ65SBTC1-32DT1
AJ65SBTC4-16DT AJ65SBTC4-16DT2 AJ65SBTCF1-32DT
AJ65FBTA42-16DT AJ65FBTA42-16DTE AJ65SBTW4-16DT
AJ65MBTL1N-16DT AJ65BTB1-16DT AJ65BTB2-16DR
AJ65SBT-64AD AJ65BT-64AD AJ65SBT-62DA
AJ65BT-64DAI AJ65BT-64DAV AJ65VBTCU68DAVN
AJ65VBTCU68ADV AJ65VBTCU68ADI AJ65BT-64RD3
AJ65BT-64RD4 AJ65BT-68TD AJ65BT-D62
AJ65BT-D62D AJ65BT-D62D-S1 AJ65BT-D75P2-S3
AJ65BT-G4-S3 AJ65BT-R2 AJ65SBT-RPT
AJ65SBT-RPS AJ65BT-RPI-10A AJ65BT-RPI-10B
A6CAP-DC1 A6CPA-WP1 A6CVR-8 A6CVR-16
A6CVR-32 A6CON-P214 A6CON-P220 A6CON-P514
A6CON-P520 A6CON-LJ5P A6CON-PWJ5P
