ÉϺ£²Æ²ýʵҵ·¢Õ¹ÓÐÏÞ¹«Ë¾¹©Ó¦ÏúÊÛ·¨¹úBEI IDEACOD±àÂëÆ÷
·¨¹úBEIIDEACODʵÐÄÖá±àÂëÆ÷ ¿ÕÐÄÖá(ä¿×)±àÂëÆ÷ ¿ÕÐÄÖá(ͨ¿×)±àÂëÆ÷
IDEACOD/IDEACOD±àÂëÆ÷
·¨¹ú°¬µÏ¿ËBEI IDEACOD ×÷Ϊ¹¤Òµ±àÂëÆ÷ÁìÓòÖÐÕæÕýµÄר¼Ò,ÔÚ³¤´ï25Äê¶àµÄʱ¼äÄÚÒ»Ö±ÖÂÁ¦ÓÚ¿Í»§ÏîÄ¿µÄʵÏÖ.BEI IDEACOD µÄ±àÂëÆ÷ÊÊÓÃÓÚ¼¸ºõ
ËùÓеĹ¤ÒµÁìÓò:¸ÖÌúÒµ¡¢·ÄÖ¯Òµ¡¢°ü×°»úÆ÷¡¢°áÔËÒµ¡¢²£Á§ÖÆÔìºÍ»úÆ÷ÈËÖÆÔìµÈ.¸Ã±àÂëÆ÷Ò²ÊÊÓÃÓÚËùÓеĿÁ¿Ì¹¤×÷»·¾³:¸¯Ê´µÄ¡¢Ò×±¬µÄÒÔ¼°
µç´Å¸ÉÈÅ»·¾³.BEI IDEACOD designs, manufactures and brings on the market a wide range of industrial rotating encoders:
customized encoder solutions,
BEI IDEACOD µÄ·þÎñÎÄ»¯ÔÚÓÚÕë¶ÔÄúµÄÐèÇóÌṩºÏÊʵĽâ¾ö·½°¸:
? ¸ù¾ÝËùÐèÐÔÄܺͼȶ¨³É±¾ÓÅ»¯²úÆ·Ó¦ÓÃ;
? ²úÆ·Ó¦¶Ô¶ñÁÓÑϾþ»·¾³µÄÍ»³öÐÔÈ·±£Á˰²×°µÄ¿É¿¿;
? µç·¡¢»úеºÍͨÐŽӿڸöÐÔ»¯×éºÏµÄ¶àÑùÐÔ±£Ö¤Á˱àÂëÆ÷ÓëʹÓû·¾³µÄ¼æÈÝ.
²»¹ÜÄúµÄÊг¡ºÍÑ¡ÔñµÄÓ¦ÓÃÊÇʲô,BEI IDEACOD ¶¼¿ÉÒÔÌṩÊÊÓòúÆ·:¹«Ë¾ÓµÓÐ×ÅһϵÁеıê×¼²úÆ·ºÍÌØÊâÐͺŲúÆ·;¹«Ë¾µÄÉÌÒµºÍ¼¼ÊõÍŶӻá
¹²Í¬Í¶Èëµ½ÌØÊâ²úÆ·µÄÉè¼ÆÖÐ.
BEI IDEACODËùÓвúÆ·µÄ¹²Í¬µã ©¤ ¸ßÆ·ÖÊ:
ISO 9001V2000
ROHS 2002/95/CE
ATEXÈÏÖ¤
BEI IDEACOD±àÂëÆ÷½«Î»Öá¢Î»ÒÆ¡¢ËÙ¶È»òÕßÊǼÓËÙ¶Èת»»³É¿É±»¿ØÖÆÆ÷»òPLC¶ÁÈ¡µÄÊýÂëÖµ.
²»Í¬°²×°ÉèÖõıàÂëÆ÷ÀàÐÍÆëÈ«:
? ʵÐÄÖá
? ¿ÕÐÄÖá(ä¿×)
? ¿ÕÐÄÖá(ͨ¿×)
ËüÃÇͨ¹ý¹âµçÂëÅ̽«ÎïÀíֵת»»³Éµç×ÓÐźÅ.
±àÂë»òÕßÓÉÂö³åÉú³É(ÔöÁ¿ÐͱàÂëÆ÷),»òÕßͨ¹ý¾ø¶ÔλÖÃÉú³É(¾ø¶ÔÖµ±àÂëÆ÷).
²âËÙ±àÂëÆ÷ºÍ¹âµç±àÂëÆ÷Ìṩһ¸öÄ£ÄâÊä³ö,ÓëÂëÅÌÔĶÁƵÂʺÍÖáµÄÐýתËٶȾù³ÉÕý±È¹ØÏµ.
¿É±à³Ì±àÂëÆ÷DIGISINETM ºÍPOSI+TMÔÊÐíÉ趨±àÂëÆ÷Êä³öµÄ²»Í¬ÐźÅ.
ATEX ϵÁÐÒÔ¹«Ë¾È«ÃæµÄ±àÂëÆ÷¼¼Êõ(ÔöÁ¿ÐÍ¡¢¾ø¶ÔÖµ¡¢²âËÙ±àÂëÆ÷)Ϊ»ù´¡,ΪÒ×±¬»·¾³µÄʹÓôøÀ´Á˽â¾ö·½°¸.
¸ÃϵÁбàÂëÆ÷°üÀ¨±¾Öʰ²È«ÐͺͷÀ±¬ÐÍÁ½´óÀà.
·Ö±æÂÊ¡¢µç·Êä³ö¡¢Í¨Ñ¸½Ó¿Ú¡¢Á¬½Ó·½Ê½¡¢Öá¾¶´óС¡¢Á¬ÖáÆ÷ºÍ·ÀתÆ÷µÈ¶àÖÖ²¿¼þµÄ²»Í¬×éºÏ,ʹBEI IDEACODµÄ±àÂëÆ÷³ÉΪÊг¡ÉÏÆ·ÖÖ×îΪ¹ã·ºµÄ
±àÂëÆ÷Ö®Ò».
´ú±íÐͺÅÈçÏÂ:
Ideacod Encoder AHM
Ideacod Encoder AIN
Ideacod Encoder AMI
Ideacod Encoder BGR
Ideacod Encoder CB9Ideacod Encoder CBM
Ideacod Encoder CDS
Ideacod Encoder CHA
Ideacod Encoder CHM
Ideacod Encoder CHT
Ideacod Encoder CHU
Ideacod Encoder DAC
Ideacod Encoder DH0
Ideacod Encoder DHK
Ideacod Encoder DHM
Ideacod Encoder DHO
Ideacod Encoder DHT
Ideacod Encoder DXM
Ideacod Encoder FIN
Ideacod Encoder GAM
Ideacod Encoder GAU
Ideacod Encoder GEU
Ideacod Encoder GHA
Ideacod Encoder GHK
Ideacod Encoder GHL
Ideacod Encoder GHM
Ideacod Encoder GHO
Ideacod Encoder GHR
Ideacod Encoder GHT
Ideacod Encoder GHU
Ideacod Encoder GHW
Ideacod Encoder GM5
Ideacod Encoder GRU
Ideacod Encoder GXU
Ideacod Encoder GZM
Ideacod Encoder HMT
Ideacod Encoder IN5
Ideacod Encoder INH
Ideacod Encoder INS
Ideacod Encoder JHK
Ideacod Encoder JHO
Ideacod Encoder MHK
Ideacod Encoder MHM
Ideacod Encoder MT4
Ideacod Encoder N25
Ideacod Encoder NEG
Ideacod Encoder OEH
Ideacod Encoder PDH
Ideacod Encoder PHM
Ideacod Encoder PHU
Ideacod Encoder SBM
Ideacod Encoder SHM
Ideacod Encoder SHN
Ideacod Encoder SHO
Ideacod Encoder SHS
Ideacod Encoder SHU
Ideacod Encoder SM1
Ideacod Encoder SNC
Ideacod Encoder SXM
Ideacod Encoder YXM
Singleturn Absolut Encoders, FHK58, CHU9, CHM5, CHM9/CBM9, CHML/CHDL, CHK5, CHA5, CHT9, Singleturn Absolut
Encoders, FHK58, CHU9, CHM5, CHM9/CBM9, CHML/CHDL, CHK5, CHA5, CHT9, Multiturn Absolut Encoder, SHU9, SHM9,
SHA5, SHM5, Field Bus Absolute Encoders, SHM5 , MHM5, SHU9 , CHM5, CHU9, SHM5, CHU9, CHM5, 58SHM5, CHA5,
58SHA5, CHM9, CHT9, CHU9, SHM5,
9416/004A mating connector
9445/002X DAC FOR 58mm?BR>
AB58TER110/1024
AB58TER210/1024
ADDITIONAL CHARGE FOR PACKING AND DELIVERY
ADDITIONAL CHARGES FOR PACKING AND DELIVERY
AK 514/573R 100P
AK514296R / 1024
CAO 2242/1024
CAO 2242/1024 SERIE:0694/11-30V/Nr:81336
CAO-2242/1024, SERIE:0694, 11-30V NO.81465
CHM510-10BT-006 CHM5_10//551C//10//CAR shaft : 10mm 11-30V, NPN~ ( OLD NAME : AHM 510 14C 6R / 1024)
CHM9125C5G11C3R
CONNECTOR 9416/004A 12PIN FEMALE CABLE 13mm?FOR PA02 5 5/60
CONNECTOR 9416/004B 12PIN FEMALE CABLE 9mm?FOR PA02
CONNECTOR 9416/013 12P PE7
Connector With Cable 3M for GHM912-59-6R-250
counterplug 9445/006P
DAC FOR 58mm?9445 / 005
DHM5_6//PG59//01000//G3R~PB 16.573 / 1000 PULSE
DHO5082G29/1024/G3R~GHT 5 08 293R / 1024
EJ8230/020-2-9416/076 2 M CABLE with Connector
EJ8230/020-2-9416/076 3 M CABLE with Connector
GA5 2242/1024,Ser.0694, 11-30V, No:81465
GHM 51051R/1000
GHM5 1057-6R 1024
GHM5 1057-6R 4999
GHM5 1057-6R 5000
GHM510576A/30 shaft:10mm, 30P, max.6000 u/min, 11-30V, 12poli, axial~PB1057 6A/30 SERIE 0592 11-30V K316
GHM5-10-5-9-6R-1024
GHM9 12 5 G5 9 01000 G6 R 1000P, 11-30V, RADIAL~PH05-599-6R-1000 With Connector & Cable 2M
GHM912/596R/1000 with Connector 9416/004
GHM912/596R/1000 with Connector 9416/004 Cable 8230/020 20Meter
GHM912-57-3R-400 shaft 12mm? 11-30 VDC, Radial Cable 2M~PH 05579/3R/400
GHM912-59-3R-250 WITH 2M CABLE
GHM912-59-3R-450
GHM912-59-6R-250
GHM912-59-6R-250 with Connector without cable
GHM912-59-6R-250 WITH CONNECTOR
GHM912-59-6R-250 with Connector with cable 3M
GHM912-59-6R-250~PH05-57969-250 WITH CONNECTOR & CABLE 2m
GHM912-59-6R-450
GHM912596R-SK3K Konfektionierung 12POL Stecker für GHM912596R mit 3M Cable
GHM9125G57400G3R05~PH05579/3R/05/400
GHT 508293R/1024
GHT 512/293R/200 DC4,5-5,5V, 6.000U/MIN, RADIAL 200P, 2M CABLE, Shaft 12mm
GHT 514-1024-010~GHT5_14/9G59//01024//G3R020 bore 14mm? 5-24VDC, Radial, Cable 2M
GHT 912396R/1024
GHT5-08-2-9-3R/1024, Holl Shaft:8mm
GHT5-08-2-9-3R/1024, Holl Shaft:8mm, IP65
GHT5-08-293R-1024
GHT5-08-293R-2000 5V/S.Nr:9710/No:G3765
GHT51 14 293R-1024
GHT5114993R/1024/REV
GHT51-14-993R-1024 bore 14mm?5-24VDC RADIAL
GHT51-14-993R-1024 with CABLE 500mm RADIAL
GHT514.1024S00~GHTS14//2G29/01/01024//00R003//**D501~(GHT51-14-293R/1024)
GHT514293R/1024
GHT514-293R/1024 bore 14mm
GHT51-4-2-9-3R/1024 Holl Shaft:14mm, IP65
GHT514-293R/1024 Holl Shaft:14mm, IP65
GHT51-4-2-9-3R/1024 Holl Shaft:14mm~IN/58/LER/001/1024, Holl Shaft:14mm
GHT514-293R/1024~GVT514-293R/1024 bore 14mm
GHT9122 G29-2000-G6
GHU 920 396 R / 500~GHR 920 / 396R / 500 680ST10~SER NO. 0296 ALIM 15-30V N:G3103
GHU 920 T/393R/100 DC11-30V, 6.000U/MIN, RADIAL 100P, 2M CABLE~GHR 920 T/393R/100 DC15-30V
( FRANCE HOHNER )
GHU 920 T/393R/1024 DC11-30V, 6.000U/MIN, RADIAL 1024P, 2M CABLE~GHR 920 T/393R/1024 DC15-30V
GHU 920393R/1200
GHU 920393R/500
GHU 920393R/800
GHU 920396R/500
GHU 920396R/800
GHU920-0500-001
S/NO : 20030306715812
GHU920-596R-600
10-30V
GHU930-596R-900 shaft:30mm?11-30V ~GHW 930596R / 900
GZMA125G55-60-G6~PA-02559/60
GZMA125G55-60-G6~PA02559/60 With Connector
GZMA125G59-0100-G2R shaft: 12mm?11-30 VDC~PA-02599 / 1000 SERIE 1093 11-30V N.G6250
H25EF45SS6000T5ABZC 4469SM18S~H25E-F45-SS-6000-T5-ABZC-4469-SM18-S P/N:924-01005-1225, S/N:CC010367
H40A-2500-AB-4469-SC
IC331 PL22/956RS/100 #PL22/956RS/100 100P, max 6.000U/min, 11-30VDC, 12POL
IN 58 LER 001 / 1024 ( NEW NAME GHT514-1024S001 )
IN 58-LER005/1024
IN58LER001/1024 S/N:9901, 5V, No:K2409
