Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú Steute¾ØÐδŴ«¸ÐÆ÷
²úÆ·Ãû³Æ£º Steute¾ØÐδŴ«¸ÐÆ÷
ÐÍ ºÅ£º
Enclosure glass-fibre reinforced polyamide
Actuator Series M permanent magnet
Protection class IP 67 to IEC/EN 60529
Contact material Rhodium
Switching system Reed contacts
Contact types NC, NO or changeover contact
Termination lead-free pre-wired cable, PVC H05VV-F or 3-pole connector to DIN 41 524
Cable section 2 x 0,5 mm2
Cable length 1, 2 or 5 m
Switching voltage max. 250 VAC/DC
Switching current 1S: 2 A; 1W: 0,5 A; -W: 1 A
Switching capacity 1S: max. 50 VA/ W; 1W: max. 15 VA/ W; -W: max. 25 VA/ W
Switching frequency max. 200 Hz
Ambient temperature -10 ¡ãC ¡­ +80 ºC
Mechanical life 109 operations
Electrical life 109 operations
Repeat accuracy ¡À 0,02 mm
Resistance to vibrations 1S: 20 g, 1W: 10 g
¹«Ë¾Ãû³Æ£º ±±¾©µÂÀ¼ÏµÍ³¿ØÖƼ¼ÊõÓÐÏÞ¹«Ë¾
µç »°£º 010 62164681 / Éò¾²
ÊÖ»ú£º 13011890458
µØ Ö·£º ±±¾©Êк£µíÇø´óÖÓËÂ13ºÅ»ª½Ü´óÏÃ11B5
ÓÊ ±à£º 100098
Ö÷ Ò³£º http://www.dorland-ex.com
  • Steute·À±¬¿ª¹Ø£¬·À±¬ÃÅ¿ª¹Ø£¬·À±¬´«¸ÐÆ÷
  • ·À±¬Õýѹ¹ñ
  • ¹©Ó¦µÂ¹úÊÀµÂÒ½ÁÆË«Ì¤°å½Å̤¿ª¹Ø
  • ¹©Ó¦µÂ¹úÊÀµÂ˫̤°åÒ½ÁƽÅ̤¿ª¹Ø
  • ¹©Ó¦µÂ¹úÊÀµÂÒ½ÁƵ¥½Å̤½ðÊô´øÕÖ¿ª¹Ø
  • ¹©Ó¦µÂ¹úÊÀµÂÒ½ÁƵ¥½Å̤½ðÊô¿ª¹Ø
  • ¹©Ó¦µÂ¹úÊÀµÂÒ½ÁƵ¥½Å̤´øÕÖ¿ª¹Ø
  • ¹©Ó¦µÂ¹úÊÀµÂÒ½ÁƵ¥½Å̤¿ª¹Ø
  • ·À±¬ÎÞ¼«µÆ
  • Steute·À±¬¿ª¹Ø£¬·À±¬½Å̤¿ª¹Ø
