RIKO TH3D,TH3D-N计时器
台湾莱震RIKO传感器系列:
方形近接传感器:SN04-N/N2/P/P2 SND04-N/N2/P/P2 SN05-N/N2/P/P2 SN10-KP2 SN20-KP2 JN04-N JND02-N RN04-N
圆形近接传感器:SC0401-N/N2/P/P2 SC0501-N/N2/P/P2 SC0801/02-N/N2/P/P2 SCS0801/02-N/N2/P/P2 SC1202/04-KP2 SC1202/04-A/A2 SCS1202/04-N/N2/P/P2 SCL1202/04-KP2 SCL1202/04-A/A2 SC1805/08-KP2 SC1805/08-A/A2 SCL1805/08-KP2 SCL1805/08-A/A2 SC3010/15-KP2 SC3010/15-A/A2 SCL3010/15-KP2 SCL3010/15-A/A2 SCP3010/15-KP2 SCP3010/15-A/A2 SCL3018-KP2
静电容式近接开关:KC1810-B3/P3 KC3025-KP2
光电传感器: RMF-DU30KP2 SU-B3 MF5-KP2 RMF10/20-KP2 RMF-CR2N
RMF-DU10/40N(塑胶头) MMF-DU10/40N(金属头) PK3-DU30N RK3-R2N PK3-5N R3JK-DU100KP2 R3JK-R5KP2 R3JK-30KP2
环形光电开关:RQ36-KP2
电源控制器:ST-1 ST-T2
光纤放大器:FZ-KP2 VRF-SN
光纤管:FR-610 FR-610-I FR-610-M FR-610-L FRC-610 FRC-610-S FRC-610-M FRC-610-L FRH-610 FRS-410 FRS-410-S FRS-410-M FRS-410-L FRC-410 FRS-310 FRC-310 FRE-410 FRE-310-M FR-510 FR-620-6F FRX-620-6F FRS-420-S67 FRW-420-S67 FRE-310-S15(0.8) FRB-420 FRZ-420 FRY-620-6F FRX-610-P FRCC-420 FRC4-310-69X FRG-410-L FGR-410 FGR-620 FRC420+FLM04 SFRC-305-21X FRC-210-22X SFRC-505-S17 FRC-620-25 FRC-310-35FA FRC-310-35FZ FRB-320-Q FRZ-320-Q FRD-420-S22Q FRE-310-S5Q(0.8) FRCH-110-S3 FRC4-320Q FRC4-110 FRH-620-6F FT-410 FT-310 FT-20ML FT-320-Q FTY-320-Q SFT1-305-S5Q(0.3) FTC4-110-H10 FT-420 FTX-620-6F FT-420-S67 FTS-310-S15(0.8) FTE-310-S45Q(0.4) FTX-420 FTY-420 FTX-410P FTC9-420 FTC4-310 FGT-420 FTH-420-F1 FGTX-420 等等
聚焦镜:FLM-02 FLSM-02 FLM-03 FLM-03-1 FLM-04 FLM-06等]
