Ïêϸ½éÉÜ:
¸ÅÊö£º
Ci-gf11ÊÇÒ»¿îÖ§³ÖGE GeniusÏÖ³¡×ÜÏßµÄÊý¾Ý¹â¶Ë»ú¡£¹â¿ÚÖ§³Öµ¥Ä£ºÍ¶àÄ£Á½ÖÖÐͺţ¬×î´ó´«Êä¾àÀë40KM£¬Âú×ãÄú³¤¾àÀëͨѶµÄÐèÒª¡£ËÙÂÊ·¶Î§£º300~921,600bps¡£Ö§³Ö-20~70¡æ¿íλ·¾³¡£·ûºÏIP30¹¤Òµ·À»¤±ê×¼¡£µçÔ´ÊäÈëÖ§³ÖAC 24V(12~32V)»òDC 24V(12~48V)¡£Ö§³ÖDIN35µ¼¹ì°²×°»ò±Ú¹Ò¡£
ÌØµã£º
1. Ö§³ÖGE Genius¹¤ÒµÏÖ³¡×ÜÏß±ê×¼£¬Í¬Ê±Ö§³ÖRS232/422/485´®¿Úת¹âÏË¡£
2. ͨ¹ýDIP²¦Â뿪¹ØÇáËÉÉèÖô®¿Ú½çÃæ, ÎÞÐèÖØÆô¡£
3. ´«Êä¾àÀë: ¶àÄ£5KM, µ¥Ä£40KM¡£
4. Ö§³Öµã¶Ôµã»òµ¥ÏË»·Í¨Ñ¶¡£
5. ×Ô¶¯¼ì²â, Ñ¡Ôñ²¨ÌØÂÊ¡£
6. Ö§³Ö15KV ESD ÀËÓ¿±£»¤¡£
7. ÄÚ½¨Ë«Ïò120 ohmÖն˵ç×è¡£
8. ÈßÓàµçÔ´ÊäÈë: AC 24V(12~32V)/ DC 24V(12~48V)¡£
9. ÊÊÓ¦¶ñÁÓµÄÓ¦Óû·¾³, IP30·À»¤µÈ¼¶£¬ÂÁÖÆ»ú¿Ç£¬DIN35µ¼¹ì°²×°£¬¹¤×÷ζÈ: -20~ 70¡æ¡£
¹æ¸ñ£º
µç½Ó¿Ú£º
1£®±ê×¼£ºEIA/TIA-232 RS-232 (ITU-7 v.28)£¬EIA/TIA-422 RS-422 (ITU-T v.11)£¬ EIA/TIA-485 RS-485 (ISO/IEC8284)¡£
2£®½çÃæ£ºRS-232 2 wires, RS-422 4wire, RS-485 2/4 wire¡£
3£®¶Ë¿ÚÊýÁ¿£º1¸öRS-232/RS-422/RS-485 ´®¿Ú£¬7-pin¿É²ðж½ÓÏß²Û¡£
4£®²¨ÌØÂÊ£º300bps ~ 921.6Kbps¡£
5£®´®¿ÚÐźţºRS-232: TxD, RxD, Signal Ground£»
RS-422: TxD+, TxD-, RxD+, RxD-, Signal Ground£»
RS-485 4w: TxD+, TxD-, RxD+, RxD-, Signal Ground£»
RS-485 2w: Data+, Data-, Signal Ground¡£
¹â½Ó¿Ú£º
1£®¹â¿Ú: 1¸öDuplex ST½Ó¿Ú¡£
2£®´«Êä¾àÀ룺¶àÄ£¹âÏË£º5KM @ 50/125um»ò62.5/125um£¬µ¥Ä£¹âÏË£º40KM@8/125um»ò 9/125um¡£
3£®²¨³¤£º¶àÄ£¹âÏË£º820nm£¬µ¥Ä£¹âÏË£º1310nm¡£
ÆäËüÖ¸±ê£º
1£®µçÔ´£ºDC 24V (12~48V)»òAC 24V (AC12~32V, 50/60Hz)£¬1.5Watts @ 24V(×î´ó)£¬3-pin¿É²ðж½ÓÏß²Û£¬º¬µØÏß½Ó¿Ú£¬Ö§³ÖÕý¸º¼¶·´½Ó±£»¤£¬Ö§³Ö0.65A¹ýÁ÷±£»¤¡£
2£®»úе¹æ¸ñ£ºDIN35µ¼¹ì»ò×ÀÃæ°²×°£¬½ðÊôÍâ¿Ç£¬·ûºÏIP-30¹¤Òµ·À»¤±ê×¼£¬³ß´ç£º24.7mm(H) x 96mm (W) x 99mm (L) º¬µ¼¹ì¡£
3£®»·¾³ÒªÇ󣺹¤×÷ζȣº-20 ¡«+70¡æ£¬¹¤×÷ʪ¶È£º5% ¡« 95% (ÎÞÄý¶)£¬´æ´¢Î¶ȣº-40 ¡« 80¡æ£¬´æ´¢Êª¶È£º5%~ 95% ÎÞÄý¶¡£ |
