Based on open industrial communication concept, provides high speed deterministic communication between real time applications such as Control applications, SoftLogic packages, and various IO modules communicating through fieldbuses.
PC总线通讯软件
Based on open industrial communication concept, Direct Link?SW1000ETH/SW1000SER is a 100% communication software solution to connect industrial networks using Ethernet TCP/IP, or serial transport.
网关
The SST Serial DeviceNet Gateway provides a simple connection between existing serial RS-232 ASCII devices and your DeviceNet network. Whether the device you are connecting is a peripheral motor controller, a bar code scanner or a printer, this solution makes the connection for you.
争端工具
Diagnostic tools help everyone from Electricians to Engineers build,validate and maintain reliable automation networks.
