²úÆ·ÐͺŠ|
ÃèÊö |
PSEN op1.1 ½ÓÊÕÆ÷ PNP no/nc M12 |
PSEN op1ÆÁ±Î´«¸ÐÆ÷ |
PSEN op1.2·¢ËÍÆ÷M12 |
PSEN op1.3·´ÉäÆ÷ PNP no/nc M12 |
·´ÉäÆ÷ |
PSEN op ·´ÉäÆ÷ |
PSEN op Stand 1000mm |
ÂäµØÊ½Ö§¼Ü |
PSEN op Stand 1200mm |
PSEN op Stand 1500mm |
PSEN op Stand 1800mm |
PSEN op Mirror 550mm |
Ð±Ãæ¾µ£¨°´¾àÀëÈÎÒâÑ¡Ôñ£© |
PSEN op Mirror 700mm |
PSEN op Mirror 900mm |
PSEN op Mirror 1000mm |
PSEN op Mirror 1270mm |
PSEN op Mirror 1600mm |
PSEN op Mirror 1800mm |
PSEN op Testpiece F 14mm £¨ÓÃÓÚÊÖÖ¸£© |
²âÊÔ°ô |
PSEN op Testpiece H 30mm £¨ÓÃÓÚÊÖ£© |
PSEN op cable axial M12 4-pole 3m |
M12£¬4оµçÀ£¬¸ù¾ÝµçÀµij¤¶ÈÓë½Ó¿ÚµÄÐÎ×´£¨Ö±½Ç£¬ÖáÏò£©ÈÎÒâÑ¡Ôñ¡£ÊÊÓÃÓÚPSENop 2H£¬·¢ËÍÆ÷£¬PSENop 2S£¬PSENop 4S½ÓÊÕÆ÷ºÍ·¢ËÍÆ÷£¬ÒÔ¼°PSENop1.1£¬PSENop1.2£¬PSENop1.3µÈϵÁÐ |
PSEN op cable axial M12 4-pole 5m |
PSEN op cable axial M12 4-pole 10m |
PSEN op cable axial M12 4-pole 30m |
PSEN op cable angle M12 4-pole 3m |
PSEN op cable angle M12 4-pole 5m |
PSEN op cable angle M12 4-pole 10m |
PSEN op cable angle M12 4-pole 30m |
PSEN op cable axial M12 5-pole 3m |
½ÓÊÕÆ÷ÅäM12£¬5оµçÀ£¬¸ù¾ÝµçÀµij¤¶ÈÓë½Ó¿ÚµÄÐÎ×´£¨Ö±½Ç£¬ÖáÏò£©ÈÎÒâÑ¡Ôñ¡£ÊÊÓÃÓÚPSEN op2HϵÁÐ |
PSEN op cable axial M12 5-pole 5m |
PSEN op cable axial M12 5-pole 10m |
PSEN op cable axial M12 5-pole 30m |
PSEN op cable angle M12 5-pole 3m |
PSEN op cable angle M12 5-pole 5m |
PSEN op cable angle M12 5-pole 10m |
PSEN op cable angle M12 5-pole 30m |
PSEN op cable axial M12 4-pole shield 3m |
·¢ËÍÆ÷ÅäM12£¬4о´øÆÁ±ÎµçÀ£¬¸ù¾ÝµçÀµij¤¶ÈÓë½Ó¿ÚµÄÐÎ×´£¨Ö±½Ç£¬ÖáÏò£©ÈÎÒâÑ¡Ôñ¡£ÊÊÓÃÓÚPSENop 2B£¬PSENop 4F£¬PSENop4H£¬PSENop 4BϵÁÐ |
PSEN op cable axial M12 4-pole shield 5m |
PSEN op cable axial M12 4-pole shield 10m |
PSEN op cable axial M12 4-pole shield 30m |
PSEN op cable angle M12 4-pole shield 3m |
PSEN op cable angle M12 4-pole shield 5m |
PSEN op cable angle M12 4-pole shield 10m |
PSEN op cable angle M12 4-pole shield 30m |
PSEN op cable axial M12 8-pole shield 3m |
½ÓÊÕÆ÷ÅäM12£¬8о´øÆÁ±ÎµçÀ£¬¸ù¾ÝµçÀµij¤¶ÈÓë½Ó¿ÚµÄÐÎ×´£¨Ö±½Ç£¬ÖáÏò£©ÈÎÒâÑ¡Ôñ¡£ÊÊÓÃÓÚPSENop 2B£¬PSENop 4F£¬PSENop 4H£¬PSENop 4BϵÁÐ |
PSEN op cable axial M12 8-pole shield 5m |
PSEN op cable axial M12 8-pole shield 10m |
PSEN op cable axial M12 8-pole shield 30m |
PSEN op cable angle M12 8-pole shield 3m |
PSEN op cable angle M12 8-pole shield 5m |
PSEN op cable angle M12 8-pole shield 10m |
PSEN op cable angle M12 8-pole shield 30m |
