特性
􀂾 DM&P SoC CPU Vortex86DX- 800MHz
􀂾 PC/104 standard compliant
􀂾 256MB DDR2 onboard
􀂾 Integrated 10/100Mbps Ethernet
􀂾 4x RS232
􀂾 Onboard 4MB SPI Flash Disk
􀂾 16-bit GPIO
系统
SoC : DM&P SoC CPU Vortex86DX-800MHZ
Cache: L1:16K I-Cache, 16K D-Cache
L2 Cache 128KB
系统内存 :板载 DDR2 256MB
BIOS: AMI BIOS
SPI Flash Disk :Onboard 4MB SPI Flash Disk
Software programmable from 30.5μ sec.to
看门狗 : 512 sec.x 2 sets (Watchdog 1 fully
compatible with M6117D)
总线接口 : PC/104 standard compliant
PC/104+ (Optional)
PC104/PC104-PIUS CPU Module
I/O
IDE接口: Enhanced IDE port
(UltraDMA-100/66/33) x1
串口 : RS-232 port x3
RS-232/422/485 port x1
并口: Parallel port x1
USB接口: 2个USB2.0接口
键盘/鼠标:1个PS/2键盘,鼠标
GPIO : 支持16-bit GPIO
音频
解码器/接口: CM119 USB audio controller
网络
Chipset : Integrated 10/100Mbps Ethernet
Speed : 10 / 100Mbps
Inerface :RJ45 connector
Standard :IEEE 802.3U 100BASE-T
compatible
显示
显示芯片 :XGI Volari Z9s
显存: Onboard 32MB VGA Memory
支持分辩率 :support resolution up
to 1280 x 1024, 16M colors
LCD 接口 :VGA and TFT Flat Panel Interface
Support
机构与环境
尺寸 : 90 x 96mm
工作温度 : -20 °C ~ +70 °C
-40 °C ~ +85 °C (Optional)
电源功耗 : Single Voltage +5V @ 740mA
