产品名称: 全封闭式平板电脑
型  号: PPCARK-1519
价  格:
品  牌: 研美olytorch
全封闭式8.4英寸工业平板电脑
CPU type Intel Celeron M- Dothan 1 GHz processor
Front Side Bus 400/533 MHz
MB Chipset Intel 82852GM + ICH4
Graphics Integrated with Intel 82852GM
Shared system memory up to 64MB
LVDS Supports data format of 18 bits/36 bits
TV-OUT/DVI TV output supporting up to 1024 x 768 graphics resolutions
Support for all NTSC and PAL formats
Provides S-video and 2pin Header for CVBS TV-out connector
DVI-D single link Transmitter up to 165MHz
DVI hot plug detection
Digital Video Out Port DVO support 12bit interface , supporting up to UXGA
Memory 1* DDR SDRAM (max. 1GB)
IDE Ultra ATA 100/66/33, 1x 40 pin 2.54mm, 1x44 pin 2.0mm
Audio AC-Link for Audio CODEC, AC’97 2.1
Mic-in / Line-in /SPDIF OUT support
LAN 1x Realtek RLT8100C 10/100 Mbps
IO function 2*16C550 UARTs RS232 pin header
1*RX/RTS/TX for RS232 signal level In/out
Supports IrDA 1.0/ASKIR protocol
Supports PS2 keyboard and mouse
USB 2* USB 2.0(external) & 4 USB 2.0(internal)
Video-In 1 port with Conexant Fusion 878A video codec
IEEE1394 Embedded 1394 link core
OHCI Compliant programming interface
32bit Power managed PCI bus interface
Integrated 400Mbit 2 ports PHY
Touch Screen C8051F321USB interface Touch screen controller
Supported 4-, 5-, 8- wire Analog Resistive touch screen
Resister range from 200 to 1000 Ohm
USB 1.1full speed sample rate (max. 300 point/s)
Expansion interface 1* Mini PCI for only PCI rev: 2.2 interface
Power On board power DC +12V ±5% convert to +3.3V/+12V/+5V for system
Dimension 200*150 mm(MB)
74.7H x 263W x 178D mm(Chassis)
9Hx 270W x 197D mm(8.4" panel)
Operating 0~60°C
Temperature Please upgrade the hard drive to industrial grade for better temperature performance
Operating Humidity 5~95% @ 60°C, non-condensing
Optional Choice
1. AU 8.4" Touch screen, 8 wires
2. mini PCI wireless LAN
3. Digital I/O board
4. upgrade to Realtek RLT8110SB/Intel 82541PI Gigabit LAN chip
5. upgrade to wide range power 9V~ 32V DC-IN ( incl. WDT/DIO & audio amplifier)
6. IDE converter board for 2.5" HDD
7. IDE to SATA card
Remark: when CN003 is choosen, only CF card can be storage device.
Remark: When opting for wide range power, only the CPU on board version can be ordered
关 键 词: 全封闭 工业平板电脑 整机散热
公司名称: 研美南京科技有限公司
联 系 人: 首席业务代表
电  话: 025-52216665 400 6866 303
手  机:
地  址: 南京市江宁区岔路口宏运大道1813号2-4-1107
邮  编: 211101
研美工控机远程维护系统
金融担保业务
全封闭式MINI盒式工控(eARK-1311)
IP68防水触摸屏电脑(PPC-104TILF)
研美工业高清播放机eAR(eARK-1311(631-QZ-32-8K))
研美17英寸工业超薄平板(PPC-170TILC)
数据保护系统
研美BOX 盒式工控机(eARK-1310K)
eARK-1361研美6(eARK-1361)
eARK-1311研美超(eARK-1311)
研美15.1超薄工业平板(PPC-151TILC)
研美5串口4DIDOBO(eARK-1368)
研美10.4英寸平板电脑(PPC-7710)
妍美3.5小主板eARK(eARK-1311MBA)
研美嵌入式BOX 盒式工(eARK-1370A)
上架式触摸液晶显示(GY-S150T)
研美12.1超薄工业平板(PPC-121TILC)
研美8.4英寸工业超薄平(PPC-840TILC)
研美10.4工业超薄平板(PPC-104TILC)
半封闭式MINI工控机(eARK-1661)
