| CPU type |
VIA Eden(V4) 500Mhz |
| Front Side Bus |
400 / 533 MHz |
| MB Chipset |
VIA CN700 + VIA VT8237R Plus |
| Graphics |
Integrated with VIA CN700 |
Shared system memory up to 64MB |
MPEG-2 hardware VLD |
Resolution up to 1600x1200 |
| Memory |
1* DDR II SDRAM 533/400 (max. 1GB) |
| IDE |
Support Compact Flash card type II for ATA interface |
| Audio |
AC-Link for Audio CODEC, AC¡¯97 2.1 |
| LAN |
3* Realtek 10/100 Mbps |
| IO function |
1x RS232 |
| USB |
2* USB 2.0(external) & 6 USB 2.0(internal) |
| SATA |
One channel connector |
SATA drive transfer rate is capable of up to 150MB/s |
| Expansion |
1 PCIe Mini Card socket for USB device only |
| Power |
On board DC +12V convert to +3.3V/+12V/+5V for system |
| Dimension |
145 x 102 mm (MB) |
| Operating |
0~60¡ãC (with CF card) / 0~45¡ãC (with HDD) |
| Temperature |
Please upgrade the hard drive to industrial grade for better temperature performance |
| Operating Humidity |
5~95%, non-condensing |
| Optional Choice |
| 1. upgrade to VIA EDEN ULV 1.0Ghz CPU (3V700D-CR10U) or VIA C7 1.5 Ghz CPU |
| 2. SATA HDD kit |
| 3. AC-Link for Audio CODEC, AC¡¯97 2.1 |
| 4. Hardware Watch Dog Timer, 0~255 sec programmable |
