µÂ¹úRESATRON encoder¡¢RESATRON±àÂëÆ÷ RESATRONÔöÁ¿ÐͱàÂëÆ÷ RESATRON¾ø¶ÔÐͱàÂëÆ÷
ÉϺ£²Æ²ýʵҵ·¢Õ¹ÓÐÏÞ¹«Ë¾×¨Òµ¹©Ó¦µÂ¹úRESATRON ±àÂëÆ÷ ÔöÁ¿ÐÍÐýת±àÂëÆ÷ µ¥È¦¾ø¶ÔÐͱàÂëÆ÷ ¶àȦ¾ø¶ÔÐͱàÂëÆ÷ ÖáÌ×ʽ±àÂëÆ÷ ¿ÕÐÄÖá±àÂëÆ÷ »¶ÓÀ´µç×Éѯ¶©¹º£¡
Æ·Ö÷ÒªÓÐÒÔϼ¸´óϵÁУº
ÔöÁ¿ÐÍÐýת±àÂëÆ÷ INCREMENTAL ROTARY ENCODER
RSR 58 ϵÁÐ §¶58mm ×î´óÂö³å100000PPR£¬×î´óתËÙ12000RPM IP65·À»¤£»
RSR 80 ϵÁÐ §¶80mm Ë«±àÂëÆ÷£¬×î´óÂö³å·Ö±ðΪ9000PPRºÍ6500PPR£¬
RSL 58 ϵÁÐ ¿ÕÐÄÖᣬÖá¾¶12MM£¬Íâ¾¶58mm ×î´óÂö³å10000PPR£¬×î´óתËÙ6000RPM IP65·À»¤£»
RSH 58ϵÁÐ ÖáÌ×ʽ±àÂëÆ÷ ÖᾶΪ6-12MMÍâ¾¶58mm ×î´óÂö³å10000PPR£¬×î´óתËÙ6000RPM IP65·À»¤£»
RSH 76 ϵÁÐ ÖáÌ×ʽ±àÂëÆ÷ Öá¾¶¿É´ï27MMÍâ¾¶76mm ×î´óÂö³å10000PPR£¬×î´óתËÙ10000RPM IP65·À»¤£»
RSH 120 ϵÁÐÖáÌ×ʽ±àÂëÆ÷ Öá¾¶¿É´ï55MMÍâ¾¶120mm ×î´óÂö³å10000PPR£¬×î´óתËÙ4000RPM IP64·À»¤£»
ÖØ¹¤Òµ×¨ÓñàÂëÆ÷ HEAVY INDUSTRIAL ENCODER
RSG 10 R ϵÁÐ ÔöÁ¿ÐÍ ¼Ó²»Ðâ¸ÖÍâ¿Ç Íâ¾¶100MM ×î´óÂö³å100000PPR×î´óתËÙ6000RPM IP67·À»¤£»
RSG 10 T ϵÁÐ µ¥È¦¾ø¶ÔÐÍ ¼Ó²»Ðâ¸ÖÍâ¿Ç Íâ¾¶100MM 12 OR 13BIT SSI INTERFACE ×î´óתËÙ10000RPM IP67·À»¤£»
RSG 10 M ϵÁÐ ¶àȦ¾ø¶ÔÐÍ ¼Ó²»Ðâ¸ÖÍâ¿ÇÍâ¾¶100MM 24 OR 25BIT SSI INTERFACE ×î´óתËÙ10000RPM IP67·À»¤£»
RSG 10 C ϵÁÐ ¶àȦ¾ø¶ÔÐÍ PC ¿É±à³Ì ¼Ó²»Ðâ¸ÖÍâ¿ÇÍâ¾¶100MM 25BIT SSI INTERFACE ×î´óתËÙ10000RPM IP67·À»¤£»
RSG 10 N ϵÁÐ µç×Ó͹ÂÖ¾ø¶ÔÐÍ ¼Ó²»Ðâ¸ÖÍâ¿ÇÍâ¾¶100MM 24BIT 16 PARALLEL INTERFACE ×î´óתËÙ10000RPM IP67·À»¤£»
RSG 10 P02 PROFIBUS DP ϵÁÐ ¶àȦ¾ø¶ÔÐÍ ¼Ó²»Ðâ¸ÖÍâ¿ÇÍâ¾¶100MM 25BIT PROFIBUS DP INTERFACE ×î´óתËÙ10000RPM IP67·À»¤£»
RSG 10 FP PROFIBUS DP ϵÁÐ µ¥È¦/¶àȦ¾ø¶ÔÐÍ ¼Ó²»Ðâ¸ÖÍâ¿ÇÍâ¾¶100MM 10 UP TO BIT PROFIBUS DP INTERFACE ×î´óתËÙ10000RPM IP67·À»¤¡£
²úÆ·Ðͺţº
RSP02 58-13+12-3-B-W1-DS¡¢RSW10¡¢RSW10+RSP02 58-13+12-3-B-W1-DS¡¢RSW30-¡¢RSW20-¡¢210704764¡¢RSC 58-13+12-P-3-W1-US¡¢RSB 58C 13+12-3-4-CAN-W1N-DS¡¢RSP02 58DP+R5W¡¢RS-BSK 411660¡¢RSR58-¡¢RSG10C-¡¢RSG10C-13+12-P-3-V1-2SS¡¢RSG10-¡¢RSG10R-¡¢RSG10R-10000-Y-3-S-V1-SS¡¢RSG10T-¡¢RSG10T13+1-G-V1-SS-H¡¢RSM58-¡¢RSM58-13+12-G-3-V6-RSG¡¢
µÂ¹úRESATRON±àÂëÆ÷
ÐͺÅÁоÙ:RSB58C13+13-3-4-CAN-W1N-DS4
RS BSK 4116 60 ÁªÖáÆ÷
RSC58-13+12-P-3-W1-US
RSF 58 P 26-3-B-W1N-DS-F2
RSF 58 P 29-3-B-W1-DS
RS GEL 500S-10/12 ÁªÖáÆ÷
RSG 10 M 13+12-G-3-V1-SS-H
RSHF 58 P 29-B-3-2N-DS
RSH 58 - RSH 75
RSH 75 P 13+12-B-3-2-DS
RSM 58-13+12-G-3-V6-RSG
RSNT-E-P-S-K-E-S10T-B
RSP02-58-13+12-3-B-W1-DS
RSP02-58 13+12-3-B-V6-DS-V
RSP02-58 13+12-3-B-W1-DS-V
RSR 58-10000-Y-3-S-V6-RSG
RSR 58-01024-Y-3-G-W1-SS
RSR58-1000-Y-3-S-V6-RSG
