产品名称: 品富 ASB-L701 Mini Express Module
型  号: ASB-L701
价  格:
Specifications:
Display Specifications
Board Size   165 x 115mm
CPU S up port   Intel Atom N270 1.6 GHz with 533MHz FSB
Chipset   Intel 945GSE + Intel ICH7M
Memo ry Support   1 x 200-pin 533/400MHz DDR2 SO-DIMM support, up to 2GB SDRAM
Graphics   GPU : Intel Graphics Media Accelerator 950VGA integrated in Intel 945GSE
   18-bit dual-channel LVDS integ rated in Intel 945GSE
    18/24 bit dual-channel LVDS support by Chrontel CH7 308B
     1 x DB15 Female connector for external
Super I/O   Winbond W83627UHG
BIOS   AMI BIOS
Storage   2 x SATA connector
    1 x Compact Flash II slot
    1 x 44-pin IDE connector
Net work
  2 x Gigabit Ethernet Port by RJ45 with LED indi cators - Ethernet controller :
     2 x PCIe by one bus Realtek 8111D
USB
  4 x USB 2.0 stack port for external
    2 x USB 2.0 header for internal
Serial
  1 x RS232 port, DB9 connector for external (COM1),
     pin 9 w/5V/12V/Ring sele ct
     1 x RS232/422/485 select hea der for internal (COM2), default RS232
     4 x RS232 header for internal (COM3 – COM6)
Digital I/O   8-bit digital I/O by header
     4-bit digital Input
     4-bit digital Output
Infrared Interface   1x Infrared Interface by 1x5-pin header
Battery   Support CR2477 battery by 2-pin header
Audio
  Support Audio via Realtek ALC655 AC97 decoder
     Support Line-in, Line-out, MIC by 2x5-pin header
Printer   1x LPT port by 2x13-pin header
Ke yboard /Mouse   1x PS2 ke yboard/mouse by 1x5 -pin wafer connector
Expansion Bus
  1x PC 104+  connector (PCI mast er 4, jumper for +3.3V & 5V select)
     1x PCIe ( PCI-e 1x +SMBUS+USB2. 0 ) mini card
Po wer Management   DC12V input
     AT/ATX support
     1 x 2x2-pin power input connector
     1 x 3-pin PS-On header
     1 x 6-pin header for inverter 12V input
Front I/O   by 2x4-pin header
     power on/off switch
     Reset switch
     Power LED status
     HDD LED status
Watchdog Timer   Software programmable 1 – 255 second by Super I/O
External I/O port   1 x COM port (COM1)
     4 x USB 2.0 Ports (stack)
     2 x RJ45 GbE Port (10/100/1000Mbps)
     1 x VGA p ort
Temperature
  Operating: 0 – 60 degree C
     Storage: -20 – 80 degree C
Humidi ty   5% - 95%, non-condensing, ope rating
Po wer Consumption   12V @1.4 5A (Intel N270 processor with 1GB DDR2 DRAM)
EMI/EMS   CE/FCC class A
Weight   TBD
关 键 词: 视频监控 电子警察 工业主板
公司名称: 品富电子科技上海有限公司
联 系 人: 孔哲人
电  话: 021-54262303
手  机:
地  址: 上海市桂平路470号14号搂5层B区
邮  编: 200233
整机IP67全防水平板电(IP67)
APC-3081 人机(APC-3081)
品富AIX-503 MI(AIX-503)
品富AIX-510 MI(AIX-510)
APC-3716嵌入式平(APC-3716)
APC-3916嵌入式平(APC-3916)
APC-3516嵌入式平(APC-3516)
APC-3517嵌入式平(APC-3517)
APC-3717嵌入式平(APC-3717)
APC-3927嵌入式平(APC-3927)
APC-3262A嵌入式(APC-3262A)
APC-3562A嵌入式(APC-3562A)
AHM-6053 人机界(AHM-6053)
AHM-6127 NEW(AHM-6127 NEW)
AHM-6057 人机界(AHM-6057)
品富 AHM-6087 (AHM-6087)
品富 AHM-6107 (AHM-6107)
品富 AHM-6058 (AHM-6058)
品富 AHM-6108 (AHM-6108)
品富 AHM-6128 (AHM-6128)
