| Size |
¡¡110x70mm |
| Audio |
¡¡ALC662 Line in/out MIC PinHeader |
| Ethernet |
¡¡1XRJ-45 10/100/1000Base-T support Wake On LAN function
1xRJ45 10/100 Base T to IP Camera |
| Vedio Capture |
¡¡CX23885 to 1 channel D1 input |
| TV-out |
¡¡SDVO CH7021 TV-out by PAL/NTSC |
| VGA-out |
¡¡VGA pin header up to 1600x1200 |
| Super I/O |
¡¡1 x Winbond 83627HG by LPC |
| I/O Connector |
¡¡USB 2.0 port x3,COMx2,GPIOx4 |
| Storage |
¡¡Internal Compact Flash socket x1 ZIF connector x1, support Ultra DMA 33/66/100 |
| Power Supply(AT/ATX) |
¡¡DC 12V +-10% input support AT and simulate ATX mode(by Jumper setting) |
Power Consumption |
¡¡< 7W |
| Environmental Specification |
¡¡0¡æ to 60¡æ (normal), -30¡æ to 80¡æ (Optional wide temp.) £»
Operating 10%~90%, non-condensing£» Non-operating 5%~95~, non-condensing |
| EMI/Safety |
¡¡Meet CE / FCC Class A ; ‧RoHS component and process |
