| System Specifications |
| CPU |
¡¡Intel Celeron M processor |
| CPU Frequency |
¡¡ULV 600MHz/1GHz (non L2 cache) |
| Chipset |
¡¡Intel 852GM + ICH4 |
| DRAM |
¡¡1x200-pin DDR SO-DIMM, support DDR266 SDRAM up to 1GB |
| BIOS |
¡¡Phoenix-Award PnP BIOS, with VGA BIOS |
| Watchdog |
¡¡1~255 secs Watchdog timer selectable w/Reset/NMI |
| Power Supply |
¡¡Support ATX power |
| Power Requirement |
¡¡+5V, +12V, -12V, +5VSB |
| Dimension |
¡¡170mm x 170mm (6.69" x 6.69") |
| Display Specifications |
| Graphics |
¡¡Built-in Intel 852GM, share system memory, Support CRT, LVDS |
| LCD Interface |
¡¡18/36-bit LVDS |
| I/O Ports |
| IDE Interface |
¡¡1 x 40-pin IDE (UDMA 33/66/100) 1 x 44-pin IDE (UDMA 33/66/100) |
| CF |
¡¡1 x compact flash slot (IDE) |
| FDD Interface |
¡¡1 |
| Bus Interface |
¡¡PCI slot, Mini-PCI Bus |
| Serial Port |
¡¡4 x COM ports, COM1/4 for RS232, COM2/3 for RS232/422/485 ( for 16550 compatible type of UART) |
| Parallel Port |
¡¡1 x parallel (SPP/EPP/ECP) |
| IrDA |
¡¡1 (SIR) |
| Keyboard |
¡¡Mini DIN connector |
| Mouse |
| LAN |
¡¡LAN 1/2 : Realtek RTL8100C(10/100 Mbps)Support Wake-on-LAN wtih ATX power |
| Audio |
¡¡AC 97 Codec, Realtek ALC655, with Line-in/Line-out/MIC/SPDIF |
| USB |
¡¡6 x USB 2.0 |
| Environment Specifications |
| Operating Temp. |
¡¡0¡ã~60¡ãC(32¡ã~140¡ãF) |
| Storage Temp. |
¡¡-40¡ã~85¡ãC(-40¡ã~185¡ãF) |
| Relative Humidity |
¡¡Operation humidity 20~90%, storage humidity 20~95% |
