| 产品名称: |
nikkidenso伺服电机
| 型 号: |
NA800 |
| 价 格: |
| 品 牌: |
日机电装nikki denso |
产品介绍: |
NIKKI DENSO 伺服电机 同步式交流伺服电机NA800系列是由从功率范围为1.6KW~15KW。他们比前代型号轻20%, 电机密度高。电机配备17bit编码器,它可以转换为绝对 值编码器。通过与高精度伺服驱动器VC系列使用,NA800 系列表明其最佳性能。 一个单位的定位角度+/-3度, 并且您可能会扩大连接单位的角度。它可以驱动您希望的角度。
Servo motor type |
NA830-162 |
NA830-332 |
NA820-402 |
NA820-602 |
NA820-752 |
NA820-113 |
NA820-153 |
Power voltage |
V |
AC200V |
Motor frange size |
mm |
130 |
180 |
220 |
Reted output |
kW/s |
1.6 |
3.3 |
4.0 |
6.0 |
7.5 |
11.0 |
15.0 |
Reted torque |
N.m |
5.09 |
10.5 |
19.1 |
28.6 |
35.8 |
52.5 |
71.5 |
kgf.cm |
51.93 |
107 |
194.9 |
291.8 |
365.2 |
535.7 |
729.6 |
Peak output torque |
N.m |
15.27 |
31.5 |
47.7 |
71.5 |
89.5 |
131.25 |
178.7 |
kgf.cm |
155.8 |
321.0 |
486.8 |
730.2 |
913.2 |
1339 |
1825 |
Rated speed |
r/min |
3000 |
2000 |
2000 |
Maximum speed |
r/min |
4500 |
3000 |
2000 |
Rated power rate |
kW/s |
43.3 |
95.1 |
123.2 |
188.8 |
224.6 |
128.2 |
164.4 |
Rated current |
A rms |
9.7 |
18.9 |
23.7 |
32.7 |
41.8 |
46.6 |
62.6 |
Peak Maximum current |
A rms |
9.2 |
18.1 |
22.8 |
31.8 |
40.7 |
44.8 |
60.1 |
Torque constant |
N.m/A±10% |
0.554 |
0.581 |
0.84 |
0.89 |
0.88 |
1.17 |
1.19 |
kgfcm/A |
5.653 |
5.93 |
8.56 |
9.16 |
8.98 |
11.9 |
12.2 |
Mechanical constant |
ms |
1.5 |
1.0 |
1.0 |
0.8 |
0.8 |
1.0 |
1.0 |
Electrical constant |
ms |
6.6 |
8.2 |
12.5 |
14.4 |
14.4 |
19.5 |
20.0 |
Rotor inertia |
gfcms |
5.98(6.12) |
11.6(11.7) |
29.5(30.2) |
43.3(43.9) |
57.0(57.7) |
215.0(217.7) |
311.0(320.0) |
kW/s |
6.1(6.24) |
11.8(11.9) |
30.2(30.9) |
44.2(44.9) |
58.2(58.9) |
219.4(222.2) |
317.3(320.1) |
Shaft friction torque |
N.m Max |
0.25(0.29) |
0.34(0.49) |
0.49(0.78) |
0.69(0.78) |
0.78(0.98) |
2.0(2.0) |
2.45(3.0) |
kgfcm Max |
2.5(3.0) |
3.5(5.0) |
5.0(8.0) |
7.0(8.0) |
8.0(10.0) |
20.4(20.4) |
25.0(30.6) |
Play in thrust direction |
mm Max |
0.5 |
0.5 |
0.5 |
Allowable radial load |
N |
490 |
784 |
784 |
kgf |
50 |
80 |
80 |
Allowable thrust load |
N |
98 |
392 |
392 |
kgf |
10 |
40 |
40 |
Encoder |
17bit Absolute/incremental |
Weight |
kg |
4.8(7.5) |
8.0(10.7) |
15(22) |
17(24) |
21(28) |
46(59) |
62(75) |
Insulation class |
Class F |
Insulation voltage |
AC1500V for 1 min. |
Insulation resistance |
DC 500V, 100MΩor higher |
Environment |
Temperature |
0~40度 |
Humidity |
85%RH or lower No condensing |
Store temperature |
-10~85度 |
Protection class |
IP65except the connector, and shaft area |
Max. Temp. for sensor area |
Encoder 85度以下 |
About, Induction voltage constant Phase resistance Phase inductance, etc.. Please ask the sales office. |
Heat sink dimensions |
1.6KW 3.3KW |
450x450xT25Aluminum plate |
4.0KW 6.0KW 7.5KW |
600x600xT25Aluminum plate |
11.0KW 15.0KW |
700x700xT25Aluminum plate |
In regards of specifications, the mentioned values are based on the surroundings temperature 40 after our recommended heat sink is installed. The allowable radial load value is measure by the position of 20 mm from the installation surface. Each values are at the temperature of 20 to 30. The value without a/the common difference is becoming an authorized value. |
Servomotor Model |
NA830-162 |
NA830-332 |
NA820-402 |
NA820-602 |
NA820-752 |
NA820-113 |
NA820-153 |
Rated voltage |
V |
DC24V ±10% |
Quiet friction torque |
N.MIN |
7.5 |
13.5 |
32 |
50 |
150 |
kgfcmMIN |
76.5 |
137.7 |
326.5 |
510.2 |
1530.6 |
Consumption power |
W |
20 |
30 |
34.7 |
25 |
45 |
Release time |
ms MAX |
(20) |
(20) |
(50) |
(140) |
(100) |
Suction time |
ms MAX |
(90) |
(90) |
(170) |
(110) |
(300) |
Purpose |
For holding still |
Servo motor type |
NA830-162 |
NA830-332 |
NA820-402 |
NA820-602 |
NA820-752 |
NA820-113 |
NA820-153 |
Power voltage |
V |
AC400V |
Motor frange size |
mm |
130 |
180 |
220 |
Reted output |
kW/s |
1.6 |
3.3 |
4.0 |
6.0 |
7.5 |
11.0 |
15.0 |
Reted torque |
N.m |
5.09 |
10.5 |
19.1 |
28.6 |
35.8 |
52.5 |
71.5 |
kgf.cm |
51.93 |
107 |
194.9 |
291.8 |
365.2 |
535.7 |
729.6 |
N.m |
15.27 |
31.5 |
47.7 |
71.5 |
89.5 |
131.25 |
178.7 |
kgf.cm |
155.8 |
321.0 |
486.81 |
730.2 |
913.2 |
1339 |
1825 |
Rated speed |
r/min |
3000 |
2000 |
2000 |
Maximum speed |
r/min |
4500 |
3000 |
2000 |
Rated power rate |
kW/s |
43.3 |
95.1 |
123.2 |
188.8 |
224.6 |
128.2 |
164.4 |
Rated current |
Arms |
5.0 |
9.5 |
11.7 |
18.1 |
20.9 |
23.4 |
31.3 |
Arms |
4.7 |
9.1 |
11.2 |
17.7 |
20.3 |
22.5 |
30.0 |
Torque constant |
N.m/A±10% |
1.073 |
1.15 |
1.69 |
1.612 |
1.76 |
2.33 |
2.38 |
kgf.cm/A |
10.95 |
11.73 |
17.27 |
16.45 |
17.96 |
23.8 |
24.3 |
ms |
1.8 |
1.2 |
1.3 |
1.0 |
0.8 |
1.0 |
1.0 |
ms |
5.5 |
6.9 |
11.0 |
13.2 |
14.2 |
19.5 |
20.2 |
Rotor inertia |
gf.cm.s |
5.98(6.12) |
11.6(11.7) |
29.5(30.2) |
43.3(43.9) |
57.0(57.7) |
215.0(217.7) |
311.0(320.0) |
kW/s |
6.1(6.24) |
11.8(11.9) |
30.2(30.9) |
43.9(44.9) |
58.2(58.9) |
219.4(222.2) |
317.3(320.1) |
N.m Max |
0.25(0.29) |
0.34(0.49) |
0.49(0.78) |
0.69(0.78) |
0.78(0.98) |
2.0(2.0) |
2.45(3.0) |
kgf.cm Max |
2.5(3.0) |
3.5(5.0) |
5.0(8.0) |
7.0(8.0) |
8.0(10.0) |
20.4(20.4) |
25.0(30.6) |
mm Max |
0.5 |
0.5 |
0.5 |
N |
490 |
784 |
784 |
kgf |
50 |
80 |
80 |
N |
98 |
392 |
392 |
kgf |
10 |
40 |
40 |
Encoder |
Weight |
kg |
4.8(7.5) |
8.0(10.7) |
15(22) |
17(24) |
21(28) |
46(59) |
62(75) |
Insulation class |
Class F |
AC2000V for 1 min |
Environment |
Temperature |
0~40度 |
Humidity |
Store temperature |
-10~85度 |
Protection class |
IP65 except the connector, and shaft area |
Encoder 85度以下 |
1.6KW 3.3KW |
4.0KW 6.0KW 7.5KW |
11.0KW 15.0KW |
In regards of specifications, the mentioned values are based on the surroundings temperature 40 after our recommended heat sink is installed. The allowable radial load value is measure by the position of 20 mm from the installation surface. Each values are at the temperature of 20 to 30. The value without a/the common difference is becoming an authorized value. | | | | |
| 关 键 词: |
nikkidenso nikki |
公司名称:
上海奥茵绅机电科技有限公司
| 联 系 人: |
耿新红
| 电 话: |
086-18964531017
| 手 机: |
13916694162 |
| 地 址: |
上海市浦东新区金桥出口加工区金豫路100号1号楼1005室 |
| 邮 编: |
201206 |
| 主 页: |
