| Item |
Unit |
NPS-FIM* |
| -401 |
-801 |
-122 |
-242 |
-402 |
-752 |
| Input power |
Integrated control power source type |
Separated control power source type |
Main power AC200/220V, 50/ 60Hz, 3 phase |
| Voltage range |
AC180V¡«AC242V¡¡*2 |
| Main circuit method |
IPM 4 quadrant bridge sine wave PWM control |
| Continuous output current(rms) |
A |
3.4 |
6.4 |
10.5 |
15 |
27 |
54 |
| nstantaneous output current(rms) |
A |
8.8 |
17.4 |
25.6 |
39 |
55 |
98 |
| Instantaneous output torque |
200%¡¡£¨some motor combination 300%£© |
| Control method |
Semi-closed loop by encoder feedback |
| Brake method |
Regenerative braking (option: Power regeneration) |
| Career frequency |
Hz |
10k |
| £¨7.5KHz, 10KHz, 15KHz, selectable£© |
| Speed control |
Speed regulation |
¡À0.01¡¡£¨Digital setting, Average value: Temp./0¡«40¡æ, Load/ Voltage fluctuation£© ¡À0.05¡¡£¨Analog setting, Average value: Load/ Voltage fluctuation£© ¡À0.3¡¡£¨Analog setting, Average value: Temp./0¡«40¡æ£© |
| Speed control range |
1 : 5000¡¡*1 |
| Field control range |
1.3¡¡£¨Max. speed 6000rpm)/ Rated output (Some motor type: Reduced rated output£© |
| Speed command |
External analog speed command: DC0¡«+10V(¡À10V/ rated speed), Input resistance about 20k¦¸(resolution: 12bits) Internal digital speed command: 7 speeds (parameter) |
| Torque limit |
External analog torque limit command (DC voltage): 0¡«+10V (+3.3V/ Rate torque), Input resistance about 20k¦¸(resolution:10bits), Forward/ Reverse: 1 channel, each(total 2ch) Internal digital torque limit value: Forward/ Reverse: 1 channel, each (parameter) |
| Torque control |
Torque command |
External torque command (DC voltage): 0¡«+10V (+3.3V/ Rate torque), Input resistance about 20k¦¸(resolution:12bits), Internal torque command: 3 commands (parameter) |
| Linearity |
¡À3% (up to rated toque, repeatability) |
| Command resolution |
1 : 500 |
| Speed limit |
External speed limit(DC voltage): Common to External speed command ¡À10V/ rated speed (common to forward and reverse) Internal speed limit: 1 point (parameter) |
| Position control |
Pulse train control |
Max. frequency 1Mpps (at 4 times) |
| Pulse train command method |
Line driver method (directional pulse): Max.250Kpps Line driver method (90¡ã phase different 2 phase pulse): Max.250Kpps Open collector method (directional pulse): Max.200Kpps |
| Pulse train compensation |
1/100 ¨Q A/B ¨Q 100¡¡£¨A,B : 1¡«65535£© |
| Position detection |
Pulse output 90¡ãphase different 2 phase pulse signal, Marker signal Output style: Line driver output Division ratio: 1/N (N=1¡«32) |
Serial communication |
RS-422A, Start/ Stop synchro. Multi-drop wiring is possible, (Communication condition parameter set is possible.) 56kbps |
Monitor function |
LCD module (installed),: Status display, Diagnostic display, I/O signal display, Alarm display (last 5 cause history) Analog monitor: Speed, Torque, Deviation, etc. (Selection by parameter) |
Control function |
2 free degree control, FF control, Vibration filter, R2 compensation, Auto. tuning, Non-interacting compensation, Dead time compensation |
Protective function |
IPM fault, Over voltage, Under voltage, Over speed, Over load, Encoder fault, Deviation over flow, Communication error, Each data and parameter error , etc.(Last 5 cause history is stored.) |
Input signal |
Deviation clear(CLR), Command pulse input inhibit(CIH), Mode select.(MD1, MD2), Local/ Remote(PC), Start(DR), Reset(RST), Emergency stop(EMG¡ù), Speed selection 1¡«3 (SS1,SS2,SS3), Torque limit(TL), Servo ON(SON), Forward over travel(FOT), Reverse over travel(ROT), |
Output signal |
Servo ready(RDY), Alarm(ALM), Warning(WNG), Speed zero(SZ), Positioning complete(PN), In Speed/ Torque limit(LIM), Brake release(BRK£© |
Option |
Data Input Unit (MDI unit), Servo ready display, Cables, etc. |
Applicable encoder |
6000 ( 2000 ) ppr¡¡£¨Selection by parameter£© |
Load inertia |
10 times or less of motor rotor inertia |
Power capacity¡¡*3 |
kVA |
1.1 |
1.8 |
3.0 |
4.7 |
7.8 |
15.3 |
No-fuse breaker (rated current)*4 |
A |
5 |
10 |
15 |
20 |
30 |
60 |
Applicable motor |
NA30- 13F-15 25F-15 |
NA100- 20F 40F 75F-10 NA30- 50F-15 |
NA100- 75F 110F-10 |
NA100- 110F 180F-10 NA30- 110F-15 |
NA100- 180F 270F-10 370F-10 NA30- 180F-15 |
NA100- 180F 270F 370AF 370F-10 550F-10 750F-10 |
Weight |
kg |
3.8 |
3.8 |
7.0 |
7.0 |
8.0 |
12.5 |
Accessories |
Regenerative resistor |
