| Item |
Unit |
NPS-FIH* |
| -113 |
-153 |
-223 |
-303 |
-373 |
| Input power |
Integrated control power source type Main power AC400/440V, 50/ 60Hz, 3 phase |
| Voltage range |
AC360V¡«AC484V¡¡*2 |
| Main circuit method |
IPM 4 quadrant bridge sine wave PWM control |
| Continuous output current(rms) |
A |
34 |
46 |
65 |
89 |
115 |
| nstantaneous output current(rms) |
A |
62 |
81 |
112 |
154 |
210 |
| Instantaneous output torque |
200%¡¡£¨some motor combination 300%£© |
| Control method |
Semi-closed loop by encoder feedback |
| Brake method |
Regenerative braking (option: Power regeneration) |
| Career frequency |
Hz |
10k |
7.5k |
| £¨7.5KHz, 10KHz, 15KHz, selectable£© |
| Speed control |
Speed regulation |
¡À0.01 ¡À0.05 ¡À0.3
£¨Digital setting, Average value: Temp./0¡«40¡æ, Load/ Voltage fluctuation£© £¨Analog setting, Average value: Load/ Voltage fluctuation£© £¨Analog setting, Average value: Temp./0¡«40¡æ£© | |
| Speed control range |
1 : 5000¡¡*1 |
| Field control range |
1.3¡¡£¨Max. speed 6000rpm)/ Rated output (Some motor type: Reduced rated output£© |
| Speed command |
External analog speed command: DC0¡«+10V(¡À10V/ rated speed), Input resistance about 20k¦¸(resolution: 12bits) Internal digital speed command: 7 speeds (parameter) |
| Torque limit |
External analog torque limit command (DC voltage): 0¡«+10V (+3.3V/ Rate torque), Input resistance about 20k¦¸(resolution:10bits), Forward/ Reverse: 1 channel, each(total 2ch) Internal digital torque limit value: Forward/ Reverse: 1 channel, each (parameter) |
| Torque control |
Torque command |
External torque command (DC voltage): 0¡«+10V (+3.3V/ Rate torque), Input resistance about 20k¦¸(resolution:12bits), Internal torque command: 3 commands (parameter) |
| Linearity |
¡À3% (up to rated toque, repeatability) |
| Command resolution |
1 : 500 |
| Speed limit |
External speed limit(DC voltage): Common to External speed command ¡À10V/ rated speed (common to forward and reverse) Internal speed limit: 1 point (parameter) |
| Position control |
Pulse train control |
Max. frequency 1Mpps |
| Pulse train command method |
Line driver method (directional pulse): Max.250Kpps Line driver method (90¡ã phase different 2 phase pulse): Max.250Kpps Open collector method (directional pulse): Max.200Kpps |
| Pulse train compensation |
1/100 ¨Q A/B ¨Q 100¡¡£¨A,B : 1¡«65535£© |
| Position detection |
Pulse output 90¡ãphase different 2 phase pulse signal, Marker signal Output style: Line driver output Division ratio: 1/N (N=1¡«32) |
Serial communication |
RS-422A, Start/ Stop synchro. Multi-drop wiring is possible, (Communication condition parameter set is possible.) 56kbps |
Monitor function |
LCD module (installed),: Status display, Diagnostic display, I/O signal display, Alarm display (last 5 cause history) Analog monitor: Speed, Torque, Deviation, etc. (Selection by parameter) |
Control function |
2 free degree control, FF control, Vibration filter, R2 compensation, Auto. tuning, Non-interacting compensation, Dead time compensation |
Protective function |
IPM fault, Over voltage, Under voltage, Over speed, Over load, Encoder fault, Deviation over flow, Communication error, Each data and parameter error , etc.(Last 5 cause history is stored.) |
Input signal |
Deviation clear(CLR), Command pulse input inhibit(CIH), Mode select.(MD1, MD2), Local/ Remote(PC), Start(DR), Reset(RST), Emergency stop(EMG¡ù), Speed selection 1¡«3 (SS1,SS2,SS3), Torque limit(TL), Servo ON(SON), Forward over travel(FOT), Reverse over travel(ROT), |
Output signal |
Servo ready(RDY), Alarm(ALM), Warning(WNG), Speed zero(SZ), Positioning complete(PN), In Speed/ Torque limit(LIM), Brake release(BRK£© |
Option |
Data Input Unit (MDI unit), Servo ready display, Cables, etc. |
Applicable encoder |
6000 ( 2000 ) ppr¡¡£¨Selection by parameter£© |
Load inertia |
10 times or less of motor rotor inertia |
Power capacity¡¡*3 |
kVA |
21 |
30 |
41 |
58 |
70 |
No-fuse breaker (rated current)*4 |
A |
50 |
75 |
100 |
125 |
150 |
Applicable motor |
NA100- 550F-20H 1100F-10H |
NA100- 750F-20H NA20- 1500-10H |
NA100- 750F-20H 1100F-20H NA20- 2200-10H |
NA20- 1500-20H 2700-10H NA100- 1100F-20H |
NA20- 1800-20H 3700-10H |
Weight |
kg |
14.5 |
27.0 |
36.0 |
36.0 |
63.5 |
Accessories |
Regenerative resistor |
