| 产品名称: |
NCS伺服驱动器
| 型 号: |
NCS |
| 价 格: |
| 品 牌: |
日机电装nikki denso |
产品介绍: |
For Synchronizing control(NCS-FI4/FS4) |
| 1) |
You can change the synchronous ratio in real time. The synchronous speed of winding axis of winding machine or feeding axis can be changed one by one. |
| 2) |
Lag of a relative position between the master axis and slave axis during operation cab be corrected by external signal. The synchronous ratio setting function and the electric shaft function are also available. | |
Line up wire winding machine |
Sectional drive printer machine |
Application |
Traverse control of Conveyer receiving unit, Wire winding machine, Coiling machine, Line up wire winding machine, etc. General Synchronizing control as Cable drawing machine and other various production lines. |
Flying Positioning control(NCS-FI3/FS3) |
| 1) |
Without stopping running work materials, constant length cut and machining can be achieved and machining tact can be remarkably reduced. |
| 2) |
50 kinds of continuous machining patterns can be executed in turns. And plural machining combination as of cut and press can be achieved to work materials. |
| 3) |
By cosine compensation function, in case of vertical blade cutting machine as Rotary shirr, from the beginning of cutting, compensation is addded to get precise vertical cutting. | |
Application |
Carton cutter, Steel plate flying cutter, Cable and pipe cutter, Push/ Pull machining, and flying cutter control of the other production lines. |
For Genral Positioning control(NCS-FI1/FS1) |
| 1) |
High speed, high accuracy, and high performance. Dedicated positioning control, combined of Positioning control and high performance servo control functions. |
| 2) |
Max.280 points of internal stored data can be used to Program run. |
| 3) |
Complete close loop control can be achieved by an external encoder (measure/ linear scale). |
| 4) |
Simple teaching (reads current value by opening current device) can be conducted. |
| 5) |
Standard spinner function can program Acceleration/ Deceleration time, Rated speed time, and Decal. stop time and easily achieve Run by speed pattern. |
Example: Spinner motion |
Positioning by angle set by spinner function |
NCS-FCS/FS-1 Basic / Expansion of each type FI10 / FS10 : Inner Stored data positioning I/O (Input : 28points / Output : 8points)・・・Basic type FI12 / FS12 : With I/O expansion board I/O (Input : 37points / Output : 18points) FI13 / FS13 : High speed communication type Remote sequence + Basic type FI15 / FS15 : Device Net type Equipped with Device Net to meet to open Network | | |
| 关 键 词: |
NCS NCS-FI NIKKIDENSO |
公司名称:
上海奥茵绅机电科技有限公司
| 联 系 人: |
耿新红
| 电 话: |
086-18964531017
| 手 机: |
13916694162 |
| 地 址: |
上海市浦东新区金桥出口加工区金豫路100号1号楼1005室 |
| 邮 编: |
201206 |
| 主 页: |
