Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ÃÀ¹únavitar±ä±¶¾µÍ·
²úÆ·Ãû³Æ£º ÃÀ¹únavitar±ä±¶¾µÍ·
ÐÍ ºÅ£º ZOOM6000
Æ· ÅÆ£º 2686
ÃÀ¹únavitar±ä±¶¾µÍ·£¬ZOOM6000ϵÁС£±¾Ìå±ä»¯·¶Î§0.7--4¡£5±¶£¬ÊµÏÖÎÞ¼¶Á¬Ðø±ä±¶¡£¹âѧÏñÖʼ«Îª³öÖÚ¡£
ÁíÍâ´Óadapterµ½attachementÓжàÖÖÐͺſÉÑ¡£¬²¢ÇÒÈÎÒâ×éºÏ¡£¹¤×÷¾àÀë´Ó30---390mm¿ÉÑ¡Ôñ£¬¹Û²âÊÓÒ°´Ó¼¸Ê®mmСµ½¼¸¸öum¿ÉÑ¡¡£
Lens
Attach.
W.D. Camera
Format/
Parameters
.5X
Adapter
.67X
Adapter
1X
Adapter
1.33X
Adapter
2X
Adapter
3.5X
Adapter
5X
Adapter
Low-High Low-High Low-High Low-High Low-High Low-High Low-High
0.25X
0.018 N.A.
1-6044
356
(nominal)
220-390
(1) W.D. range
Mag. 0.09X-0.56X 0.12X-0.75X 0.18X-1.13X 0.24X-1.5X 0.35X-2.25X 0.63X-3.95X 0.88X-5.62X
Field 1/4" 45.70-7.12 34.03-5.33 22.85-3.56 17.18-2.68 11.42-1.78 6.53-1.02 4.54-0.72
Field 1/3"
68.64-10.64 51.12-8.04 34.32-5.32 25.80-4.0
17.16-2.66
9.8-1.52 6.88-1.08
Field 1/2"
91.36-14.16 68.06-10.66 45.68-7.08 34.34-5.32 22.84-3.54 13.05-2.02 9.12-1.44
Field 2/3" 91.40-19.52 93.62-14.66 62.84-9.76 47.25-7.34 31.42-4.88 17.95-2.79 12.56-1.96
0.5X
0.035 N.A.
1-60110
175
(nominal)
143-187
(1) W.D. range
Mag. 0.18X-1.13X 0.24X-1.50X 0.35X-2.25X
0.46X-2.99X
0.70X-4.50X
1.22X-7.87X 1.75X-11.25X
Field 1/4"
22.85-3.56 17.02-2.66 11.42-1.78 8.59-1.34 5.71-0.89 3.26-0.51 2.28-0.36
Field 1/3"
34.32-5.32
25.56-4.0 17.16-2.67 12.9-2.01 8.58-1.33 4.90-0.76 3.43-0.53
Field 1/2" 45.68-7.08 34.03-5.33 22.85-3.56 17.18-2.68 11.42-1.77 6.58-1.02 4.57-0.71
Field 2/3" 45.70-9.76 46.81-7.33 31.43-4.89 23.63-3.68 15.71-2.44 8.98-1.40 6.29-0.98
0.75X
0.054 N.A.
1-60111
113
(nominal)
100-119
(1) W.D. range
Mag. 0.27X-1.69X 0.35X-2.25X 0.53X-3.38X 0.70X-4.49X 1.05X-6.75X 1.85X-11.83X 2.63X-16.88X
Field 1/4" 15.22-2.38
11.34-1.78 7.61-1.19 5.72-0.89 3.81-0.59 2.17-0.34 1.52-0.24
Field 1/3" 22.86-3.56 17.04-2.67 11.43-1.78 8.59-1.34 5.72-0.89 3.26-0.51 2.29-0.35
Field 1/2" 30.46-4.74 22.69-3.56 15.23-2.37 11.45-1.78 7.62-1.19 4.35-0.68 3.05-0.47
Field 2/3" 30.50-6.52 31.21-4.89 20.95-3.26 15.75-2.45 10.48-1.63 5.98-0.93 4.19-0.65
NONE
0.071 N.A.
92
(nominal)
81-93
(1) W.D. range
Mag. 0.35X-2.25X
0.47X-3.00X
0.70X-4.50X
0.93X-5.89X 1.40X-9.00X 2.45X-15.75X 3.50X-22.50X
Field 1/4" 11.42-1.78 8.51-1.33 5.71-0.89 4.29-0.67 2.86-0.45 1.63-0.25 1.14-0.18
Field 1/3" 17.16-2.67 12.77-2.01 8.58-1.33 6.45-1.0 4.29-0.67 2.45-0.38 1.72-0.27
Field 1/2" 22.85-3.56 17.01-2.67 11.42-1.77 8.59-1.33 5.71-0.89 3.26-0.50 2.28-0.36
Field 2/3" 22.90-4.89 23.40-3.65 15.71-2.44 11.81-1.83
7.86-1.22
4.49-0.70 3.14-0.49
1.5X
0.104 N.A.
1-60112
51
(nominal)
48-52
(1) W.D. range
Mag. 0.53X-3.38X
0.71X-4.50X
1.05X-6.75X 1.40X-8.98X 2.10X-13.50X 3.67X-23.62X 5.25X-33.75X
Field 1/4" 7.61-1.19 5.67-0.89 3.81-0.59
2.86-0.44 1.91-0.30 1.09-0.17 0.76-0.12
Field 1/3" 11.43-1.78 8.52-1.33 5.72-0.89 4.3-0.67 2.86-0.44 1.63-0.25 1.14-0.18
Field 1/2" 15.23-2.37 11.34-1.77 7.62-1.19 5.73-0.89 3.81-0.59 2.18-0.34 1.52-0.24
Field 2/3" 15.00-3.26 15.60-2.44 10.48-1.63 7.88-1.22 5.24-0.81 2.99-0.46 2.10-0.33
2.0X
0.141 N.A.
1-60113
36
(nominal)
34-37
(1) W.D. range
Mag. 0.70X-4.50X
0.94X-6.00X
1.40X-9.00X
1.86X-11.97X
2.80X-18.00X
4.9X-31.5X 7.00X-45.00X
Field 1/4" 5.71-0.89 4.26-0.67 2.86-0.45 2.15-0.34 1.43-0.23 0.82-0.13 0.57-0.09
Field 1/3" 8.58-1.33 6.39-1.00 4.29-0.67 3.22-0.50 2.15-0.33 1.22-0.19 0.86-0.13
Field 1/2" 11.42-1.77 8.51-1.33 5.71-0.89 4.29-0.67 2.86-0.44 1.63-0.25 1.14-0.18
Field 2/3" 11.40-2.44 11.70-1.83 7.86-1.22 5.91-0.92 3.93-0.61 2.24-0.35 1.57-0.24
NOTE: The above fields of view are measured diagonally in millimeters (Horizontal = Diagonal x 0.8 and Vertical = Diagonal x 0.6).
(1) Working distance range when using 12 mm fine focus. Field of view will change with longer or shorter working distances
¹«Ë¾Ãû³Æ£º ÉϺ£¿¬Íþ¹âµç¿Æ¼¼ÓÐÏÞ¹«Ë¾
µç »°£º 021 37633336 / ÖìÒú
ÊÖ»ú£º 13917834838
µØ Ö·£º Ëɽ­ÇøÊ¢Áú·650ºÅºç¡´óÂ¥707ÊÒ
ÓÊ ±à£º 201516
Ö÷ Ò³£º http://www.kwell-mv.com
  • ÃÀ¹úAI¹âÔ´
  • ÈÕ±¾VST¾µÍ·HϵÁÐ
  • ÈÕ±¾VST¾µÍ·LDϵÁÐ
  • ÈÕ±¾hayashiÏÔ΢¾µ¹âÔ´
  • Ë«²àÔ¶ÐľµÍ·
  • ¶¨±¶¾µÍ·
  • ¶¨±¶¾µÍ·
  • ¶¨±¶¾µÍ·
  • Òâ´óÀûoptoË«²àÔ¶ÐľµÍ·
  • ÃÀ¹úAIµã¹âÔ´SL073-530IC
