产品介绍: |
The versatile modular design of the compact MOXA EDS-608 series Ethernet switch allows users to combine fiber and copper modules to create switch solutions suitable for any automation network. The EDS-608's modular design lets you install up to 8 fast Ethernet ports, and the advanced Turbo Ring and Turbo Chain (recovery time < 20 ms) technology and RSTP/STP (IEEE 802.1w/D) helps increase the reliability and availability of your industrial Ethernet network. Models with an extended operating temperature range of -40 to 75°C are also available. The MOXA EDS-608 series supports several reliable and intelligent functions, including IEEE 1588 PTP, Modbus/TCP, LLDP, DHCP Option 82, SNMP Inform, QoS, IGMP snooping, VLAN, IEEE 802.1X, HTTPS, SSH, SNMPv3, and more, making the Ethernet switches suitable for any harsh industrial environment.
