CPU SUPPORT |
Intel® ATOM™
Z510P 1.1GHz, 512K Cache, 400MHz FSB;
Z530P 1.6GHz, 512K Cache, 533MHz FSB; |
CHIPSETS |
l Intel®US15W System Control Hub |
MEMORY |
1 x 200-pin SO-DDR2 DIMM socket, up to 2GB 400/533MHz SO-DDR2 |
DISPLAY INTERFACE |
Analog VGA, Digital LVDS |
INTERNAL STORAGE DEVICES SUPPORT |
1.8¡± HDD Connector, parallel ATA master
CF Card Slot, parallel ATA slave
SD Card Slot for SD/SD 2.0/MMC Card |
EXTERNAL PORTS |
l 2 x USB 2.0 Type-A Connector
l 2 x RS232C + 1 x USB Combo Connector
l 2 x RS232C + 1 x USB Cradle Connector
l VGA D-Sub Connector
l Earphone Jack
l Battery Connector
l DC Input Jack |
COMMUNICATION |
One Mini-PCIe Card Slot for HSDPA 3.5G Card
One USIM Card Slot |
SYSTEM BIOS (FWH) |
8M-bit AWARD Flash BIOS with ACPI, APM support |
POWER SUPPLY |
AC: 60 Watts Switching Power Adapter, UL/CE/PSE Certified Input: 100-240V AC, Output 12V DC, 5.0A
DC: 7.4V / 3600mAH Li-ion Rechargeable Battery Pack (2S2P) |
OPERATING SYSTEM |
Windows 7™, Windows Vista™, XP/2000/NT4.0/ME/9x, Linux® |
OPERATING ENV. |
Ambient Temperature: 0º C - 40º C (operating), -10º C - 50º C (Storage) |
DIMENSIONS |
203 x 267 x 40 |
