1-phase DC inverter compressor driver
1: General features
- 180˚ sensorless sine wave driving control solution
- Built-in rectification / switch power supply circuit, PTC resistor
- RS485 or photo-coupler-isolated UART communication
- Short circuit, over-current, over-heat, under-voltage protection
2: General spec
No. |
Items |
Spec |
1 |
AC input power voltage (V) |
1-phase, 220V, 230V |
2 |
Working voltage range (V) |
AC165V ~ 260V |
3 |
Input power supply frequency (Hz) |
50/60Hz ¡À 5% |
4 |
Max input current (A) |
35A |
5 |
Working temperature range(¡æ) |
£20 ~ 65¡æ |
6 |
Working humidity range (%RH) |
20 ~ 95 |
7 |
Power Factor |
£¾ 0.95 (after PFC works) |
8 |
Output frequency range£¨Hz£© |
10 ~ 110Hz (dependent on compressor performance) |
9 |
Cooling method |
Heat sink wind cool |
10 |
applicable capacity range (btu) |
24000 ~ 54000btu |
3: Hardware system block diagram
Consist of rectification, PFC control, PTC resistance, compressor driving, switching power supply, micro processor, and other peripheral circuits.
4: Applications
Widely used for 1-phase AC power input, 24000¡«54000btu systems of DC inverter air-con system, VRF system, Duct system, water-source system, heat pump hot water system, etc.
