产品名称: 3.5 工業主板
型  号: DT-A3100S
VIA Eden-V4(400MHz/500MHz/600MHz/800MHz/1.0GHz/1.2GHz) / C7(1.0/1.3/1.5GHz)
Processor
. VIA VIA Eden-V4/C7 + VIA CX700(M) Chipset
. 1 x 200-pin SODIMM Socket Supports DDR2 533 SDRAM up to 1GB
. Supports DVI Display
. Supports TV OUT Display (Option)
. Supports LVDS Display
. Supports One Channel IDE Interface (Two Devices)
. Compact Flash Socket
Specification:
CPU
. VIA Eden-V4 400MHz
. VIA Eden-V4 500MHz
. VIA Eden-V4 600MHz
. VIA Eden-V4 800MHz
. VIA Eden-V4 1.0GHz
. VIA Eden-V4 1.2GHz
. VIA C7 1.0GHz
. VIA C7 1.3GHz
. VIA C7 1.5GHz
System Memory
. 1 x 200-pin SODIMM Socket for DDR2 533 SDRAM up to 1GB
Chipset
. VIA CX700(M) Chipset
BIOS
. Award system BIOS (Plug & Play)
. Supports “Power on” after power failure
. Supports Wake on LAN
. 4MB flash ROM
On-board LAN
. 2 x RJ-45 connector
Audio
. AC97 2.0 CODEC compatible
. MIC-in, Line-in, Line-out
Display
. 1 x DVI-I connector(VGA & DVI)
. 1 x TV OUT connector(Pin Header)(Option)
. 1 x 18/24bit LVDS connector
I/O Interface
. Serial Port: One D-SUB 9-pin connector for RS232
One 2 x 5 (2.0mm) box header for RS232
Two 2 x 5 (2.0mm) box header for RS232/422/485
. Universal Serial Bus: Supports 6 x USB2.0 connector (Rear x 2, Internal x4)
. Parallel Port: One 2 x 13 (2.0mm) box header to support SPP / EPP / ECP mode
. PS/2: One Mini-Din connector for keyboard and mouse
. On-board One compact flash Socket(Type-II socket)
. IDE Interface: One 2 x 22 (2.0mm) box header
On-board RTC
. Internal RTC supporting by CX700(M)
Storage
. 2.5”HDD: One 44-pin connector (secondary)
. Compact Flash: On-board One compact flash Socket(Primary)
Expansion Slot
. One Mini PCI socket (Option)
System Power
. ATX Power Supply(DC 5V/12V/5VSB)
Environment
. Board Level Operating Temperature: 0℃~60℃
. System Level Operating Temperature: 0℃~40℃
. Storage Temperature: -20℃~80℃
. Relative Humidity: 5~90% @40℃
Dimensions
. 146 x 102 mm
Daughter Boards
l         12V DC-DC Power Board
l         Connector Board: 4 x USB / Audio (Mic-In/
      Line-In/Spk-Out) / 1 x Power button /
      1 x Reset button / 2 x LED indicators
关 键 词: VIA 3.5 EDEN
公司名称: 岱爾科技有限公司
联 系 人: Michael
电  话: 886-229992208
手  机: 886-932392448
地  址: 台灣台北縣三重市重新路五段609巷18號6樓之4
邮  编: 241
10.4 寸 Panel(DT-PPC800LX)
DT-C35Q 工業機箱(DT-C35Q)
Atom 迷你工控機(DT-B1110S)
17 Panel PC (DT-PPC965)
19 Panel PC (DT-PPC945G)
Core 2 Duo 雙(DT-B1105S)
Core 2 Duo 工(DT-B1104)
Core 2 Duo 雙(DT-B1104S)
Core 2 Quad (DT-BMX35Q)
Core 2 Duo 工(DT-BMX945G)
DT-C945(DT-C945)
DT-C1104 工業機(DT-C1104)
DT-C3100 工業機(DT-C3100)
DT-C2100 工業機(DT-C2100)
DT-C1100 工業機(DT-C1100)
3.5 VIA 計算機系(DT-B3100)
AMD 計算機系統(DT-B2100)
Pentium Cele(DT-B1100)
Atom Mini IT(DT-K1130)
AMD LX800 工業(DT-M2100)
