产品名称: SANO智能型电子伺服变压器
型  号: IST-C-050
价  格:
SANO伺服变压器可配伺服电机(Sano servo transformer goes servo system):
MITSUBISHI(三菱伺服), YASKAWA(安川伺服),SANYO(三洋伺服),FUJI(富士伺服),HITACHI(日立伺服),PANASONIC(松下伺服),OMRON(欧姆龙伺服),ROCKWELL(罗克韦尔伺服),FANUC(发那科伺服),SCHNEIDER(施耐德伺服),LUST(路斯特伺服),KEB(科比伺服),LENZE(伦茨伺服),DELTA(台达伺服),TECO(东元伺服
), And so on, all domestic server system等所有国内外伺服系统
主要功能:输入:三相四线380V  50HZ/60HZ   输出:三相三线200V  50HZ/60HZ
Main Features: INPUT: 380V   50-60HZ       OUTPUT: 200V 50-60HZ
产品尺寸: 长125MM*宽110MM*高43MM
功能特点:Features
(1)智能型(随需应变)Intellective model (as desired)
根据伺服系统所需电流自动调节,输出电流不受电网电压波动的影响,使伺服电机发挥更好的性能,集灵活,智能于一体。
Auto-adjustment as per the required current for the servo system, no any affection to the output current caused by the voltage fluctuation, which enable the servo motor reaching excellent performance with combination of flexibility and intellection.
(2)外型精巧,灵活安装Nice Shape, easy installation
盒式外型,体积小(巴掌般大小) 随意安装
Case-model shape with small size (like palm) for easy installation
(3) 安全可靠Reliable Quality
质保五年,没有返修率,寿命长达二十年以上
With 5 year warranty period without any defection rate, up to over 20 years working time
(4) 贴合中国使用环境Suited to application condition in China
300%至500%的过载能力,可长时间连续工作
允许电压波动范围宽
承受苛刻使用环境:周围空气温度-65℃至+68℃,安装海拔可达4500m
300%---500& overload with long time continues working
Wide allowed voltage fluctuation
Steady working under rigorous working status: Workable under -65℃---+68℃, installation up to 4500m height above sea level
(5) 低价格Low Price
较传统工频变压器便宜
Much cheaper compared with the traditionaltransformer
(6) 性能优越Excellent Performance
      高效率(99.8%),高稳压,无干扰,不发热,耗电少,输出能量更稳定
High Efficiency(99.8%), High Fixed Voltage, Non-Interference, Non-Heating, Low-Consumption, Reliable Output Energy
典型应用: Main Application
      数控机床,包装机械,印刷机械,自动化生产线等二十多个自动化设备行业
Numerical controlling Machine Tool, Packing Machine, Printing Machine, Auto-Production Line etc over 20 different auto-equipment fields
产品选型
IST-----C-----100------ R
005 : 0.5KVA
010 : 1.0KVA
015 : 1.5KVA
020 : 2.0KVA
600:60.0KVA
关 键 词: 电子伺服变压器 EST 变压器
公司名称: 深圳市三锘科技有限公司
联 系 人: 宋飞
电  话: 0755-83765658
手  机: 13590358544
地  址: 深圳市福田区华强赛格科技园
邮  编: 518000
英迈克伺服专配三相变压器(IST-C-150-R)
电子伺服变压器(IST-C-150-R)
智能伺服变压器(IST-C-100)
品牌智能伺服变压器(IST-C-050)
高保护三相智能伺服变压器(IST-C-050)
东能伺服专用变压器(SANOIST-C-050)
380V转200V三相伺(IST-C-030)
东元伺服电机专用变压器(IST-C-075)
SANO品牌三相伺服变压(IST-C-050)
伺服电机专用变压器【量大(IST-C-045)
三菱伺服专用变压器(IST-C-020)
