| System |
| CPU |
Intel® Socket P supports Core™2 Quad/ Core™2 Duo/ Celeron® M with 45nm process technology |
| FSB |
1066/800/667 MHz |
| BIOS |
AMI 32Mb BIOS |
| System Chipset |
Intel GM45 + ICH9M-E |
| I/O Chip |
Winbond W83627DHG-A+Fintek 81216G |
| System Memory |
2 200-pin SODIMM sockets support up to 4GB Dual Channel DDR2 800MHz SDRAM |
| SSD |
One Compact Flash Type I/II Socket (optional) |
| Watchdog Timer |
Reset: 1 sec. to 255 sec/min. and 1 sec. or 1 min./step |
| H/W Status Monitor |
Monitoring CPU temperature, voltage, and cooling fan status. Auto throttling control when CPU overheats |
| Expansion |
1 Mini PCI-E, 1 PCI-E x 1, 1 PCI 2.3 |
| TPM |
Intel Integrated TPM 1.2 |
| S1/S2/S3 |
Yes |
| SmartFan Control |
Yes |
| I/O |
| MIO |
4 SATA II, 8 USB, 5 RS-232, 1 PS/2 Keyboard+Mouse |
| USB |
8 USB 2.0 |
| GPIO |
16-bit General Purpose I/O for 8-bit DI and 8-bit DO |
| Display |
| Chipset |
Intel 65nm Mobile GMCH Integrated Graphics 4500MHD |
| Display Memory |
Intel DVMT 5.0 supports up to 512MB Video Memory |
| Resolution |
2048 x 1536 @ 75 MHz |
| Dual Display |
VGA+HDMI, LVDS+HDMI, VGA+DVI, LVDS+DVI |
| HDMI |
On Board |
| LVDS |
Dual channel 24-bit LVDS |
| DVI |
TI SN75DP139 DisplayPort to TMDS Transmitter |
| Audio |
| Audio Codec |
Realtek ALC888, 5.1+2 CH HD Audio 6W x 2-CH Amplified |
| Audio Interface |
Mic-in, Line-in, Line-out |
| Ethernet |
| LAN 1 |
Intel 82567LM Gigabit LAN |
| LAN 2 |
Intel 82574L PCI-E Gigabit LAN for 2nd LAN (Optional) |
| Back Panel I/O Port |
1 PS/2 Keyboard+Mouse (Through Y-Cable) 1 RS-232 with 5V/12V power 1 VGA port 1 DVI port 1 HDMI port 4 USB 2.0/1.1 1 LAN RJ45 ports (2nd LAN optional) Audio I/O (3 jacks) |
| Internal I/O Connector |
2 USB Connectors support Additional 4 USB Ports 1 24-pin ATX Power 4 COM Port Headers (no box), 1 with 5V/12V Power 4 SATA Connectors 1 Audio Amplifier Connector 1 Front Audio 1 Front Panel 1 S/PDIF Out 1 LVDS Connector 1 Inverter Power Connector 1 CPU Fan Connector 1 System Fan Connector 1 Digital IO Header |
| Mechanical & Environmental |
| Power Requirement |
0.591A@19V (with Core 2 Duo T7100 1.8GHz & 1GB DDR2 SDRAM) |
| Power Type |
ATX |
| Operating Temperature |
0 to 60°C (32 to 140°F) |
| Operating Humidity |
0% to 90% relative humidity, non-condensing |
| Size (L x W) |
6.69" x 6.69" (170 mm x 170 mm) |
| Weight |
0.88lbs (0.4Kg) |
