Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú Mini ITX IX945GSE3
²úÆ·Ãû³Æ£º Mini ITX IX945GSE3
ÐÍ ºÅ£º IX945GSE3
Æ· ÅÆ£º ±ØÉý
Download
Product Spec [PDF]
Manual & Drivers
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Onboard Intel FCBGA8 45nm Atom N270 Processor
FSB
533MHz
BIOS
Award 16Mb Flash ROM BIOS
System Chipset
Intel 945GSE + ICH7-M Chipset
I/O Chip
Winbond W83627DHG-A
System Memory
One 200-pin SODIMM up to 2GB Single Channel DDR2 533 SDRAM, non-ECC
SSD
Optional, one CompactFlash Type I/II socket
Watchdog Timer
Reset: 1 sec. to 255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring temperatures, voltages, and cooling fan status. Auto throttling control when CPU overheats
Expansion
1 PCI (PCI Rev. 2.3 compliant), 1 Mini PCI-E
S3/S4
Yes
TPM
Optional, TPM1.2 (Infineon TPM chip 9635 TT 1.2)
Wake up on LAN or Ring
LAN (PME/RPL)
I/O
MIO
1 EIDE, 2 SATA II, 8 RS-232, 1 K/B, 1 Mouse
USB
6 USB 2.0
GPIO
16-bit General Purpose I/O for 8-bit DI and 8-bit DO
Display
Chipset
Intel 945GSE integrated Graphics Media Accelerator 950
Display Memory
Intel DVMT 3.0 supports 224MB video memory
Max Resolution
VGA 1: Supports up to QXGA (2048 x 1536)
VGA 2: Supports up to WUXGA (1920 x 1200)
LVDS: Supports up to UXGA (1600 x 1200)
VGA
Dual VGA
VGA 1
On board GMA 950 supports CRT resolution up to QXGA
VGA 2
Chrontel CH7317A/B supports resolution up to WUXGA
LVDS
Optional, 18-bit dual channel LVDS resolution up to UXGA
LVDS Backlight
Yes
Power Connector
1 12V CPU Fan Connector
1 12V Chassis Fan Connector
Audio
Audio Codec
RealtekR ALC888, 5.1 + 2 Channel HD Audio
Audio Interface
Mic-in, Line-in, Line-out
Audio Amplifier (W)
Optional, TPA3005D2 Stereo 6 Watt
Ethernet
LAN 1
Realtek RTL8111C Gigabit LAN
LAN 2
Back Panel I/O Port
Back Panel I/O Port
1 PS/2 Keyboard
1 PS/2 Mouse
2 VGA ports
2 COM ports w/ Power
2 RJ45 ports
4 USB 2.0/1.1
Audio I/O (3 jacks)
Internal I/O Connector
2 COM Ports w/ Power, 4 COM Ports w/o Power
1 20-pin ATX Power Connector
1 CPU Fan Connector
1 Chassis Fan Connector
1 USB Connector supports additional 2 USB Ports
1 18-bit LVDS Connector (optional)
1 LVDS Invertor Connector
1 IDE Connector
2 SATA II Connectors
1 Digital IO Header
1 Front Panel Header
1 S/PDIF Out Header
1 Front Audio Connector
1 Mini PCI-E
1 PS/2 KB/MS Header
Mechanical & Environmental
Power Type
ATX
Operating Temperature
0 to 60¡æ (32 to 140¨H)
Operating Humidity
0% to 90% relative humidity, non-condensing
Size (L x W)
6.69" x 6.69" (170 mm x 170 mm)
Weight
0.88 lbs (0.4 Kg)
Ordering Information
IX945GSE3
Intel 945GSE supports Intel FCBGA8 45nm Atom N270 Mini-ITX Motherboard with Dual VGA, Dual-CH LVDS, Audio, 2 GigaLAN, 8 COM, 6 USB 2.0, 1 PCI, 1 Mini PCI-E, 16-bit DIO
90I-945S12-M0000B2
IX945GSE3 Mini-ITX Motherboard w/ TPM & Amp., CF, LVDS
90I-945S12-M0001B2
IX945GSE3 Mini-ITX Motherboard w/o TPM & Amp., CF, LVDS
¹«Ë¾Ãû³Æ£º ±ØÉý¿Æ¼¼¹É·ÝÓÐÏÞ¹«Ë¾
µç »°£º 8862 27961888 / ³ÂС½ã
ÊÖ»ú£º
µØ Ö·£º ̨±±ÊÐÄÚºþÇøÈð¹â·26Ïï20Ū1ºÅ6Â¥
ÓÊ ±à£º 114
Ö÷ Ò³£º www.bcmimb.com
  • Compact Flash Card
  • VGA Card AD-8001
  • Embedded PC FCX230
  • Embedded PC FCX231
  • Embedded PC ACX430
  • Embedded PC ECX330
  • Embedded PC ECX331
  • Embedded PC TCX120
  • Embedded PC ELF-500
  • Embedded PC ELF-300
