产品名称: Mini ITX IX945GSE2
型  号: IX945GSE2
品  牌: 必升
Download
Product Spec [PDF]
Manual & Drivers
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Onboard Intel FCBGA8 45nm Atom N270 Processor
FSB
533MHz
BIOS
Award 16Mb SPI BIOS
System Chipset
Intel 945GSE + ICH7-M Chipset
I/O Chip
Winbond W83627DHG-A
System Memory
One 200-pin SODIMM up to 2GB Single Channel DDR2 533 SDRAM, non-ECC
SSD
One CompactFlash Type I/II socket
Watchdog Timer
Reset: 1 sec. to 255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring temperatures, voltages, and cooling fan status. Auto throttling control when CPU overheats
Expansion
1 PCI (PCI Rev. 2.3 compliant), 1 Mini PCI-E
S3/S4
Yes
TPM
Optional, TPM1.2 (Infineon TPM chip 9635 TT 1.2)
Wake up on LAN or Ring
LAN (PME/RPL)
I/O
MIO
1 EIDE, 2 SATA II, 8 RS-232, 1 K/B, 1 Mouse
USB
6 USB 2.0
DIO
16-bit General Purpose I/O for 8-bit DI and 8-bit DO
Display
Chipset
Intel 945GSE integrated Graphics Media Accelerator 950
Display Memory
Intel DVMT 3.0 supports 224MB video memory
Max Resolution
CRT: Supports up to QXGA (2048 x 1536)
LVDS: Supports up to UXGA (1600 x 1200)
Dual Display
VGA+18-bit LVDS or VGA+24-bit LVDS
VGA
On board GMA 950 supports CRT resolutions up to QXGA
LVDS
Supports dual channel LVDS resolutions up to UXGA 18-bit and 24-bit Single/Dual channel
LVDS Backlight
Yes
Power Connector
1 12V CPU Fan Connector
1 12V Chassis Fan Connector
Audio
Audio Codec
Realtek ALC888, 5.1 + 2 CH HD Audio
Audio Interface
Mic-in, Line-in, Line-out
Audio Amplifier (W)
Optional, TPA3005D2 Stereo 6 Watt
Ethernet
LAN 1
Realtek RTL8111C Gigabit LAN
LAN 2
Back Panel I/O Port
Back Panel I/O Port
1 PS/2 Keyboard
1 PS/2 Mouse
1 VGA port
2 COM ports
2 RJ45 ports
4 USB 2.0/1.1
Audio I/O (3 jacks)
Internal I/O Connector
2 COM Ports w/ Power, 4 COM Ports w/o Power
1 20-pin ATX Power Connector
1 CPU Fan Connector
1 Chassis Fan Connector
1 USB Connector supports additional 2 USB Ports
1 24/18-bit LVDS Connector
1 LVDS Invertor Connector
1 IDE Connector
2 SATA II Connectors
1 Digital IO Header
1 Front Panel Header
1 S/PDIF Out Header
1 Front Audio Connector
1 Mini PCI-E
1 PS/2 KB/MS Header
Mechanical & Environmental
Power Type
ATX
Operating Temperature
0 to 60℃ (32 to 140℉)
Operating Humidity
0% to 90% relative humidity, non-condensing
Size (L x W)
6.69" x 6.69" (170 mm x 170 mm)
Weight
0.88 lbs (0.4 Kg)
Ordering Information
IX945GSE2
Intel® 945GSE Supports Intel® FCBGA8 45nm Atom™ N270 Mini-ITX Motherboard with VGA, 2-CH LVDS, Audio, 2 GigaLAN, 8 COM, 6 USB 2.0, 1 PCI, 1 Mini PCI-E, 16-bit DIO & 6W AMP
90I-945S09-M0000B2
IX945GSE2 Mini-ITX Motherboard w/ TPM & Amp.
90I-945S09-M0001B2
IX945GSE2 Mini-ITX Motherboard w/o TPM & Amp.
关 键 词: 必升 嵌入式主板
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
Compact Flas
VGA Card AD-(AD-8001)
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX7(NX700CXM)
Nano ITX NX1(NX15MXL)
Nano ITX NX1(NX15MXL2)
Nano ITX NXL(NXLNP)
ATX AX35Q(AX35Q)
ATX AX45Q(AX45Q)
ATX AX45Q2(AX45Q2)
ATX BV945GR(BV945GR)
ATX AX45Q3(AX45Q3)
