²úÆ·Ãû³Æ£º
Mini ITX IX45GM
ÐÍ ºÅ£º
IX45GM
±ØÉý
Supports Intel® Socket P Core™2 Quad/ Core™2 Duo/ Celeron® M 45nm CPU |
Intel® GM45 + ICH9M-E Chipset |
Two 200-pin SODIMMs up to 4GB dual channel DDR2 800MHz SDRAM |
Intel 65nm Mobile GMCH Integrated Graphics 4500MHD |
Dual Display: VGA/DVI/HDMI/LVDS |
Realtek ALC888, 5.1 + 2 Channel with 2 independent HD Streaming Audio |
Intel 82567LM GbE LAN, Intel 82574L PCI-E GbE LAN for 2nd LAN (Optional) |
1 Mini PCI-E, 1 PCI-E x 1, 1 CF socket, 1 PCI 2.3 |
5 COM, 8 USB, 4 SATA II |
TPM 1.2, AMT 4.0 |
Specifications
System |
CPU |
Intel® Socket P supports Core™2 Quad/ Core™2 Duo/ Celeron® M with 45nm process technology |
FSB |
1066/800/667 MHz |
BIOS |
AMI 32Mb BIOS |
System Chipset |
Intel GM45 + ICH9M-E |
I/O Chip |
Winbond W83627DHG-A+Fintek 81216G |
System Memory |
2 200-pin SODIMM sockets support up to 4GB Dual Channel DDR2 800MHz SDRAM |
SSD |
One Compact Flash Type I/II Socket (optional) |
Watchdog Timer |
Reset: 1 sec. to 255 sec/min. and 1 sec. or 1 min./step |
H/W Status Monitor |
Monitoring CPU temperature, voltage and cooling fan status. Auto throttling control when CPU overheats. |
Expansion |
1 Mini PCI-E, 1 PCI-E x 1, 1 PCI 2.3 |
TPM |
Intel Integrated TPM 1.2 |
S1/S2/S3 |
Yes |
SmartFan Control |
Yes |
I/O |
MIO |
4 SATA II, 8 USB, 5 RS-232, 1 PS/2 Keyboard+Mouse |
USB |
8 USB 2.0 |
GPIO |
16-bit General Purpose I/O for 8-bit DI and 8-bit DO |
Display |
Chipset |
Display Memory |
Intel DVMT 5.0 supports up to 512MB Video Memory |
Resolution |
2048 x 1536 @ 75 MHz |
Dual Display |
VGA+HDMI, LVDS+HDMI, VGA+DVI, LVDS+DVI |
HDMI |
On Board |
LVDS |
Dual channel 24-bit LVDS |
DVI |
TI SN75DP139 DisplayPort to TMDS Transmitter |
Audio |
Audio Codec |
Realtek ALC888, 5.1 + 2 CH HD Audio 6W x 2 CH Amplified |
Audio Interface |
Mic-in, Line-in, Line-out |
Ethernet |
LAN 1 |
Intel 82567LM Gigabit LAN |
LAN 2 |
Intel 82574L PCI-E Gigabit LAN for 2nd LAN (Optional) |
Back Panel I/O Port |
1 PS/2 Keyboard+Mouse (Through Y-Cable) 1 RS-232 with 5V/12V power 1 VGA port 1 DVI port 1 HDMI port 4 USB 2.0/1.1 2 LAN RJ45 ports (2nd LAN optional) Audio I/O (3 jacks) |
Internal I/O Connector |
2 USB Connectors support additional 4 USB Ports 1 24-pin ATX Power Connector 4 COM Port Headers (no box), 1 with 5V/12V Power 4 SATA Connectors 1 Audio Amplier Connector 1 Front Audio 1 Front Panel 1 S/PDIF Out 1 LVDS Connector 1 Inverter Power Connector 1 CPU Fan Connector 1 System Fan Connector 1 Digital IO Header |
Mechanical & Environmental |
Power Requirement |
0.591A@19V (with Core 2 Duo T7100 1.8GHz & 1GB DDR2 SDRAM) |
Power Type |
16V to 24V DC-in |
Operating Temperature |
0 to 60¡ãC (32 to 140¡ãF) |
Operating Humidity |
0% to 90% relative humidity, non-condensing |
Size (L x W) |
6.69" x 6.69" (170 mm x 170 mm) |
Weight |
0.88lbs (0.4Kg) |
Ordering Information |
IX45GM
Intel GM45 Mini-ITX Motherboard with VGA, DVI, HDMI, Audio, Dual Gb LAN, 5 COM, 4 SATA, 8 USB, 1 Mini PCI-E, 1 PCI-E x 1, 1 PCI 2.3, 16-bit DIO |
