Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú Mini ITX IX910GMLE2
²úÆ·Ãû³Æ£º Mini ITX IX910GMLE2
ÐÍ ºÅ£º IX910GMLE2
Æ· ÅÆ£º ±ØÉý
Download
Product Spec [PDF]
Manual & Drivers
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Socket 478 type
FSB
400 MHz
BIOS
Award 4 Mb Flash ROM BIOS
System Chipset
Intel 82910GMLE GMCH/82801FBM ICH6-M
I/O Chip
Winbond W83627DHG-A
System Memory
Two 240-pin SO DIMM socket supports up to
2 GB DDR2 400 SDRAM
SSD
One Compact Flash Type I/II socket
Watchdog Timer
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring CPU temperature and cooling fan status Auto throttling control when CPU overheats
Expansion
One PCI slot (PCI Rev. 2.2 compliant) supports 3 PCI master
S3
S3 Support
SmartFan Control
Yes
I/O
MIO
1 xEIDE (Ultra DMA 100), 2 x SATA, 8 x RS-232,
1 x K/B, 1 x Mouse
COM
COM1/2/3/4/ 5/6 ports as RS-232 ; COM1/2/3/4
pin-9 with +5V & +12V powered,COM 7/8 as RS232/422/485 by jumper
USB
8 x USB 2.0
DIO
16-bit General Purpose I/O for DI and DO
(8 in/8 out with 2.0 pin header)
Display
Chipset
Intel 82910GMLE GMCH integrated Graphics
Media Accelerator 900
Display Memory
Intel DVMT 3.0 supports up to 128 MB video memory
Resolution
2048 x 1536 @ 32 bpp (75 Hz)
Dual Display
CRT + LVDS
LVDS
Dual-channel 18-24bit LVDS
Audio
Audio Codec
Realtek ALC655 supports 5.1 ch. Audio
Audio Interface
Mic in, Line in,Line out
Ethernet
LAN 1
Realtek RTL8110SC Gigabit LAN
Back Panel I/O Port
Back Panel I/O Port
1 x PS/2 Keyboard / 1 x PS/2 Mouse / 2 x RS-232/1 x VGA port / 4 x USB 2.0/1.1 / 1 x RJ45 Port
5.1 CH Audio I/O (3 jacks)
Internal I/O Connector
* 2 x USB connectors support additional 4 USB ports
* 1 x 20-pin ATX Power connector
* 1 x IDE 40-pin connector for two devices
* 6 x COM port header (2.0 by 36 pin for Com 3 to Com 6,
2.0 by 9pin for Com 7 and Com 8)
* 2 x SATA connectors
* 1 x System panel connector
* 1 x LPT SPP/ECP/EPP with 26-pin 2.54 pitch box-header
* 1 x LVDS connector
* 1 x Inverter Power connector
* 1 x CPU Fan connector
* 1 x System Fan connector
* 1 x Digital IO header
Mechanical & Environmental
Power Type
TBD
Operating Temperature
0~60¡ãC (32~140¡ãF)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
6.69" x 6.69" (170 mm x 170 mm)
Weight
1.1 lbs (0.5 kg)
Ordering Information
IX910GMLE2
Mini ITX Main Board with VGA, 1-CH LVDS,Audio, Gb LAN, 8 COM,8 USB 2.0& 1 PCI
¹«Ë¾Ãû³Æ£º ±ØÉý¿Æ¼¼¹É·ÝÓÐÏÞ¹«Ë¾
µç »°£º 8862 27961888 / ³ÂС½ã
ÊÖ»ú£º
µØ Ö·£º ̨±±ÊÐÄÚºþÇøÈð¹â·26Ïï20Ū1ºÅ6Â¥
ÓÊ ±à£º 114
Ö÷ Ò³£º www.bcmimb.com
  • Compact Flash Card
  • VGA Card AD-8001
  • Embedded PC FCX230
  • Embedded PC FCX231
  • Embedded PC ACX430
  • Embedded PC ECX330
  • Embedded PC ECX331
  • Embedded PC TCX120
  • Embedded PC ELF-500
  • Embedded PC ELF-300
