System |
CPU |
Onboard Intel® FCBGA8 45nm Atom N270 Processor |
FSB |
533MHz |
BIOS |
Award 16Mb SPI BIOS |
System Chipset |
Intel 945GSE + ICH7-M Chipset |
I/O Chip |
Winbond W83627DHG-A |
System Memory |
One 200-pin SODIMM up to 2GB Single Channel DDR2 533 SDRAM, non-ECC |
SSD |
One CompactFlash Type I/II socket |
Watchdog Timer |
Reset: 1 sec. to 255 min. and 1 sec. or 1 min./step |
H/W Status Monitor |
Monitoring temperatures, voltages, and cooling fan status. Auto throttling control when CPU overheats |
Expansion |
1 PCI (PCI Rev. 2.3 compliant) supports 3 PCI master |
S3/S4 |
Yes |
TPM |
TPM1.2 (Infineon TPM chip 9635 TT 1.2) |
Wake up on LAN or Ring |
LAN (PME/RPL) |
I/O |
MIO |
1 EIDE, 2 SATA II, 4 RS-232, 1 K/B, 1 Mouse |
USB |
6 USB 2.0 |
DIO |
16-bit General Purpose I/O for 8-bit DI and 8-bit DO |
Display |
Chipset |
Intel 945GSE integrated Graphics Media Accelerator 950 |
Display Memory |
Intel DVMT 3.0 supports 224MB video memory |
Max Resolution |
CRT: Supports up to QXGA (2048 x 1536) LVDS: Supports up to UXGA (1600 x 1200) |
Dual Display |
Dual view, dual channel LVDS, DVI |
VGA |
On board GMA 950 supports CRT resolutions up to QXGA |
LVDS |
Supports dual channel LVDS resolutions up to UXGA 18-bit Single/Dual channel |
LVDS Backlight |
Yes |
Power Connector |
1 12V CPU Fan Connector 1 12V Chassis Fan Connector |
DVI |
DVI-D |
Audio |
Audio Codec |
Realtek ALC888, 5.1 + 2 CH HD Audio |
Audio Interface |
Mic-in, Line-in, Line-out |
Audio Amplifier (W) |
Optional, TPA3005D2 Stereo 6 Watt |
Ethernet |
LAN 1 |
Realtek RTL8111C Gigabit LAN |
LAN 2 |
Back Panel I/O Port |
1 PS/2 Keyboard 1 PS/2 Mouse 1 VGA port 1 DVI port 2 COM ports 2 RJ45 ports 4 USB 2.0/1.1 Audio I/O (3 jacks)
Internal I/O Connector |
2 COM Ports w/ Power 1 20-pin ATX Power Connector 1 CPU Fan Connector 1 Chassis Fan Connector 1 USB Connector supports additional 2 USB Ports 1 18-bit LVDS Connector 1 LVDS Invertor Connector 1 IDE Connector 2 SATA II Connectors 1 Digital IO Header 1 Front Panel Header 1 S/PDIF Out Header 1 Audio Amplifier Connector 1 Front Audio Connector 1 Mini PCI-E 1 PS/2 KB/MS Header
Mechanical & Environmental |
Power Type |
ATX |
Operating Temperature |
0 to 60¡æ (32 to 140¨H) |
Operating Humidity |
0% to 90% relative humidity, non-condensing |
Size (L x W) |
6.69" x 6.69" (170 mm x 170 mm) |
Weight |
0.88 lbs (0.4 Kg) |
