产品名称: Mini ITX IX700CXM
型  号: IX700CXM
品  牌: 必升
Download
Product Spec [PDF]
Manual & Drivers
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
VIA C7 1 GHz onboard
FSB
400 / 800 MHz
BIOS
Award 4 MB Flash ROM BIOS
System Chipset
VIA CX700M
I/O Chip
Winbond W83627DHG-A
System Memory
One 200-pin SO-DIMM socket supports up
to1 GB DDR2 400/533 SDRAM
Watchdog Timer
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring CPU temperature, voltage, and cooling fan status. Auto throttling control when CPU overheats
Expansion
One PCI slot (PCI Rev. 2.3 compliant)
TPM
Infineon SLB9635TT TPM onboard
Wake up on LAN/Ring
Supports LAN and Ring modes (PME / RPL / WOR)
S3 / S4
Yes
SmartFan Control
Supports 3 modes in Silent / Optimal /Performance modes
I/O
MIO
1 x EIDE, 1x LPT, 2 x SATAII, 4 x RS-232 (5V/12V), 1 x K/B, 1 x Mouse
USB
6 x USB 2.0
DIO
8-bit DIO (4-bit in / 4-bit out)
Display
Chipset
Integrated VIA UniChrome Pro II 3D/2D AGP graphics with MPEG-2/4 and WMV9 accelerator
Display Memory
VIA S3 UniChrome Pro II 3D Graphic Engine Shared system memory up to 128MB I/O
Max. Resolution
1920 x 1440 @75Hz
Dual Display
CRT + DVI, CRT + LVDS, Single DVI+Single LVDS
VGA
Yes
LVDS
Dual-channel 18/24-bit LVDS
LVDS Backlight power connector
Yes
DVI
Yes
Audio
Audio Codec
Realtek ALC888, 7.1 w/o Multiple Streaming or 5.1+2 with Multiple Streaming HD Audio
Audio Interface
Mic in, Line in, Line out
Audio Amplifer
Dual 6W Amp.(TPA3005D2 )
Ethernet
LAN 1
Realtek RTL8110SC Gigabit LAN
LAN 2
Back Panel I/O Port
Back Panel I/O Port
1 x PS2 mouse port / 1 x PS2 keyboard port/ 1 x VGA port / 1 x DVI-I port / 2 x RS-232 (5V/12V)/2 x LAN ports / 4 x USB 2.0 ports / Audio I/O (3 jacks)
Internal I/O Connector
1 x LVDS connector
1 x inverter power connector
2 x RS-232 (5V/12V)
2 x SATA connectors
1 x Parallel port connector
1 x USB 2.0 connector for 2 USB ports
1 x DIO connector (4 IN/ 4 OUT)
1 x Amplifier connector
1 x Front panel header
1 x 20 pinATX power connector
1 x Front panel audio connector
1 x CPU fan connector
1 x system fan connector
1 x SPDIF connector
1 x AT/ATX mode selection jumper
Mechanical & Environmental
Power Type
AT/ATX
Operating Temperature
0~60℃ (32~140℉)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
6.69" x 6.69" (170 mm x 170 mm)
Weight
0.88 lbs (0.4 Kg)
Ordering Information
IX700CXM
VIA C7 1 GHz Mini ITX Motherboard with VGA, DVI, LVDS, Audio, Dual LAN,
PCI, CF, 4 COM, 2 SATA, 6 USB & 8-bit DIO
关 键 词: 必升 嵌入式主板
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
Compact Flas
VGA Card AD-(AD-8001)
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX7(NX700CXM)
Nano ITX NX1(NX15MXL)
Nano ITX NX1(NX15MXL2)
Nano ITX NXL(NXLNP)
ATX AX35Q(AX35Q)
ATX AX45Q(AX45Q)
ATX AX45Q2(AX45Q2)
ATX BV945GR(BV945GR)
ATX AX45Q3(AX45Q3)
