产品名称: Micro ATX MX41G
型  号: MX41G
品  牌: 必升
Download
Product Spec [PDF]
Manual & Drivers
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Intel® LGA775 socket supports Core™2 Quad/ Core™2 Duo with 45nm process technology
FSB
1333/1066/800 MHz
BIOS
AMI 32Mb BIOS
System Chipset
Intel® G41 + ICH7R Chipset
I/O Chip
Winbond W83627DHG-A
System Memory
Two 240-pin DIMM sockets support up to 8GB Dual Channel DDR2 800/667 SDRAM
Watchdog Timer
Reset : 1 to 255 sec/min per step
H/W Status Monitor
Monitoring temperature, voltage, and cooling fan status. Auto throttling control when CPU overheats.
Expansion
1 PCI-E x 16, 1 PCI-E x 4,
2 PCI slots (PCI 2.3 compliant)
Power State
S1, S3, S4, S5
TPM
Onboard TPM 1.2 by Infineon SLB9635 (optional)
Wake up on LAN or Ring
LAN (PXE)
SmartFan Control
Yes, CPU Fan (by SIO)
I/O
MIO
4 SATA II, 9 COM RS-232, 1 COM RS-232/422/485, 1 LPT, 1 PS/2 KB+MS
USB
8 USB 2.0
GPIO
PCA9555 supports 16-bit General Purpose
I/O for 8-bit DI and 8-bit DO
Display
Chipset
Intel® G41 integrated Graphics Media
Accelerator X4500
Display Memory
Intel® DVMT 4.0 supports up to 352MB Memory
Max. Resolution
2048 x 1536 (@75Hz)
Dual Display
LVDS + VGA
VGA
On board
LVDS
18-bit single channel LVDS/ 24-bit dual channel LVDS, up to 1600 x 1200 resolution
LVDS Backlight
Yes, 5V and 12V
DVI
Yes, support by ADD2 card
HDMI
2nd VGA
LVDS+VGA, ADD2+VGA/LVDS
Audio
Audio Codec
Realtek ALC888, 5.1 + 2 CH HD Audio
Audio Interface
Line-in, Line-out, Mic-in
Ethernet
LAN 1
Realtek RTL8111D GbE LAN
LAN 2
Back Panel I/O PortBack Panel I/O Port
Back Panel I/O Port
1 VGA (D-Sub) Connector,
1 Dual COM Port Double Stack (w/ Power),
2 LAN RJ45 Ports,
2 USB 2.0,
Audio I/O (3 jacks)
Internal I/O Connector
1 KB+MS Pin Header,
1 IDE Connector,
4 SATA/SATA II Connectors,
2 USB Connectors support 4 USB Ports,
8 COM Headers,
1 LVDS Connector,
1 LVDS Backlight Connector,
1 CPU Fan Connector,
1 System Fan Connector,
1 Chassis Intrusion Header,
1 Front Audio Connector,
1 Front Panel Header,
1 LPT,
1 16-bit DIO Connector,
1 AT/ATX Power Jumper
Mechanical & Environmental
Power Requirement
+12V (0.3A), +5V (2.1A), +3.3V (1.3A), 5VSB (0.3A)
Power Type
AT/ ATX
Power Connector
1 24-pin ATX Power Connector
1 4-pin ATX 12V Power Connector
Operating Temperature
0 to 60°C (32 to 140°F)
Operating Humidity
0% to 90% relative humidity, non-condensing
Size (L x W)
9.6” x 9.6” (243.84 mm x 243.84 mm)
Weight
1.35 lbs (0.6 Kg)
Ordering Information
MX41G
90M-G41001-M0000B2
MX41G R10 STD LGA775
关 键 词: 必升 嵌入式主板
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
Compact Flas
VGA Card AD-(AD-8001)
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX7(NX700CXM)
Nano ITX NX1(NX15MXL)
Nano ITX NX1(NX15MXL2)
Nano ITX NXL(NXLNP)
ATX AX35Q(AX35Q)
ATX AX45Q(AX45Q)
ATX AX45Q2(AX45Q2)
ATX BV945GR(BV945GR)
ATX AX45Q3(AX45Q3)
