产品介绍: |
Intel® LGA775 socket for Intel Core™2 Quad / Core™2 Duo Processors Compatible with Intel next generation 45nm Multi-Core CPU, TDP 95W |
Intel Q45 / ICH10DO support Intel AMT5.0 / Matrix Storage / vPro/ iTPM |
Support four DIMM, max. 8GB, DDR2 800 / 667 MHz, non-ECC, un-buffered memory.Dual channel memory architecture |
Intel Graphics Media Accelerator 4500 integrated Dual DVI output (DVI-I+DVI-D) |
Realtek ALC888, 5.1+2 CH with Multiple Streaming HD Audio |
Intel 82567-LM PCI-E Gigabit LAN support iAMT5.0 Intel 82541PI PCI Gigabit LAN Controller |
1 x PCI-E 2.0 x16, 1 x PCI-E x4, 1 x PCI-E x1, 1 x PCI 2.3 |
1 x DVI-I + DVI-D Double Stack,2 x COM with power,12 x USB 2.0(8F/ 4R),6 x SATA/SATAII support Intel RAID 0,1,5,10,1 x PS2 KB/MS |
S/PDIF Out Header,16bit DIO, 6W Stereo Audio amp. Output |
Specifications
| System |
| CPU |
Intel® LGA775 socket for Intel® Core™2 Quad / Core™2 Duo Processors Compatible with Intel® next generation 45nm Multi-Core CPU |
| FSB |
1333 / 1066 / 800 MHz |
| BIOS |
Award 32 Mb SPI BIOS |
| System Chipset |
Intel Q45 GMCH/ICH10DO |
| I/O Chip |
Winbond W83627DHG-A |
| System Memory |
Four 240-pin DIMM sockets support up to 8 GB Dual Channel DDR2 800 / 667 MHz |
| Watchdog Timer |
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step |
| H/W Status Monitor |
Monitoring temperatures, voltages, and cooling fan status. Auto throttling control when CPU overheats |
| Expansion |
1 x PCI-E 2.0 x16 , 1 x PCI-E x4 ,1 x PCI-E x1,1 x PCI 2.3 |
| DIO |
16Bit (8 in / 8 out) |
| S3/S4 |
Yes |
| TPM |
Intel Integrated TPM1.2 |
| Wake up on LAN or Ring |
LAN (PXE / RPL) |
| SmartFan Control |
Yes , Intel QST for CPU_FAN, Smart FAN control for CHA_FAN & SYS_FAN |
| Display |
| Chipset |
Intel Graphics Media Accelerator 4500 integrated |
| Display Memory |
Intel DVMT 4.0 supports up to 352 MB video memory |
| Max. 3D Resolution |
2048 x 1536 bpp(@ 75Hz) |
| Dual Display |
DVI-I & DVI-D |
| VGA |
Yes , through ADD2 card |
| LVDS |
| DVI |
Yes , dual DVI (DVI-I & DVI-D) |
| HDMI |
| Audio |
| Audio Code |
Realtek ALC888, 5.1 +2 CH. with Multiple Streaming HD Audio |
| Audio Interface |
Line-out, Line-in, Mic-in |
| Audio Amplifier |
TPA3005D2 6W Stereo audio amplier |
| Ethernet |
| LAN 1 |
Intel 82567-LM PCI-E Gigabit LAN support iAMT 5.0 |
| LAN 2 |
Intel 82541PI PCI Gb LAN controller |
| Back Panel I/O Port |
1 x PS/2 Keyboard , 1 x PS/2 Mouse,1 x DVI-I + DVI-D Double Stack, 2 x COM Port , 2 x RJ45 port,4 x USB 2.0/1.1 , 1 x Audio Jack (3ports) |
| Internal I/O Connector |
* 4 x USB connectors (PH:2.54mm)support additional 8 USB ports * 6 x SATA connectors * 1 x CPU Fan connector( 4pin PWM) * 1 x Chassis Fan connector (3pin,Tacho sensor) * 1 x System Fan connector (3pin,Tacho sensor) * 1 x 16bit Digital I/O pin (8in/8out) * 1 x 4-pin Audio Amp. * 1 x Front panel header * 1 x S/PDIF Out Header * 1 x Chassis Intrusion header * 1 x 24-pin ATX Power connector * 1 x 4-pin ATX 12V Power connector |
| Mechanical & Environmental |
| Power Requirement |
Total 105w(1.67A@ 3.3V, 3.3A @ 5V, 6.05A@ 12V) |
| Power Type |
AT/ATX mode |
| Operating Temperature |
0~60°C (32~140°F) |
| Operating Humidity |
0%~90% relative humidity, non-condensing |
| Size (L x W) |
9.6" x 9.6" (243.84 mm x 243.84 mm) |
| Ordering Information |
MX45Q2
Intel Q45 LGA775 Micro ATX Motherboard with DVI-I+DVI-D, Audio, Dual Gb LAN, 2 COM,6 SATA, 12 USB, 1 PCI-E2.0 X16, 1 PCI-EX4,1 PCI-Ex1, 1 PCI 2.3, 16-bit DIO |
