Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú Micro ATX MX945GC
²úÆ·Ãû³Æ£º Micro ATX MX945GC
ÐÍ ºÅ£º MX945GC
Æ· ÅÆ£º ±ØÉý
Download
Product Spec [PDF]
Manual & Drivers
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Intel® ¦ÌFC-LGA 775 socket supports Core™ 2 Duo/ Core™ Duo® / Pentium® 4 / Celeron® D with 65nm process technology
FSB
1066/800/533 MHz
BIOS
AMI / Award 4 Mb Flash ROM BIOS
System Chipset
Intel® 82945GC GMCH/ ICH7
I/O Chip
Winbond W83627EHG-A
System Memory
Two 240-pin DIMM sockets support up to 2 GB Dual Channel DDR2 667/533 SDRAM
Watchdog Timer
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring temperatures, voltages, and cooling fan
status. Auto throttling control when CPU overheats
Expansion
One PCI Express X16, one PCI Express X1, two PCI slots(PCI Rev. 2.2 compliant)
S3
S3 support
SmartFan
Yes
I/O
MIO
1 x EIDE (Ultra DMA 100), 4 x SATA, 1 x FDD , 1 x LPT, 2 x RS-232, 1x K/B, 1 x Mouse
USB
8 x USB 2.0
Display
Chipset
Intel® 82945GC GMCH integrated Graphics Media
Accelerator 950
Display Memory
Intel® DVMT 3.0 supports 224 MB video memory
Max. Resolution
2048 x 1536 @ 32 bpp (75Hz)
External VGA
PCI-E X16 VGA interface
HDMI
Through ADD2 HDMI Card (Customized BIOS required)
LVDS
Through ADD2 LVDS Card (Customized BIOS required)
DVI
Through ADD2 DVI Card (Customized BIOS required)
2nd VGA
Through ADD2 VGA Card (Customized BIOS required)
Audio
Chipset
Intel® ICH7
Audio Codec
Realtek ALC882 7.1-channel High Definition Audio Codec
Audio Interface
Mic in, Line in, CD Audio in, Line out, S/PDIF
Ethernet
LAN 1
Intel® 82573L Gigabit LAN
Back Panel I/O Port
Back Panel I/O Port
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x Parallel port
1 x Serial port
1 x VGA port
1 x RJ45 port
4 x USB 2.0/1.1
Audio I/O (6 jacks)
Internal I/O Connector
2 x USB connectors support additional 4 USB ports
1 x 24-pin ATX Power connector
1 x 4-pin ATX 12V Power connector
1 x Floppy disk drive connector
1 x IDE connector for two devices
1 x COM connector
1 x Power / Standby LED (green)
1 x Chassis intrusion connector
1 x CD audio in connector
1 x TPM connector
4 x SATA connectors
1 x Front panel audio connector
1 x S/PDIF out connector
1 x Speaker connector
1 x System panel connector
1 x CPU Fan connector
1 x System Fan connector
1 x Power Fan connector
Mechanical & Environmental
Power Type
ATX
Operating Temperature
0~50¡ãC (32~122¡ãF)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
9.6¡± x 9.6¡± (243.84 mm x 243.84 mm)
Weight
0.88 lbs (0.4 Kg)
¹«Ë¾Ãû³Æ£º ±ØÉý¿Æ¼¼¹É·ÝÓÐÏÞ¹«Ë¾
µç »°£º 8862 27961888 / ³ÂС½ã
ÊÖ»ú£º
µØ Ö·£º ̨±±ÊÐÄÚºþÇøÈð¹â·26Ïï20Ū1ºÅ6Â¥
ÓÊ ±à£º 114
Ö÷ Ò³£º www.bcmimb.com
  • Compact Flash Card
  • VGA Card AD-8001
  • Embedded PC FCX230
  • Embedded PC FCX231
  • Embedded PC ACX430
  • Embedded PC ECX330
  • Embedded PC ECX331
  • Embedded PC TCX120
  • Embedded PC ELF-500
  • Embedded PC ELF-300
